Here is the customization sheet and instructions for the unicorn '10-'13 GXs without nav. User configurable setting changes are made on the dashboard multi-info display
I haven't confirmed these but FSM claims these HVAC settings can be further customized with Techstream. Some of these are already known and can be altered elsewhere but you will notice the new ones.
It only beeps if the power is ON, otherwise no beep.
What I did was, when engine is on, i shifted to R, press parking brakes, take foot off brakes then press on/off. Camera stays on and no beep. Even if I shift to P, the camera still stays on. I’m on the Acc power and not on ON
Do the reverse lights stay on when u still have the camera on
I didn’t check but you don’t put it in R for long. Just put in R, camera will engage, leave in R, turn off engine then put it in P. The camera will stay on until you turn it off or change screen.
Before and after changes I made today. I can always revert if I don't like it. Some may like more auto settings but I wanted to try some more manual control
Want to get TechStream as I will be adding Crawl soon and everytime i turn off the engine, I really don't like the seat moving backwards because the kids has less room to get out in the rear with booster seats. Can you just buy any J2534 cable or what is everyone's recommendation?
You can adjust the seat to Off/Partial/Full by going into the Vehicle Customization from the NAV system. It doesn't need TS. The steering wheel telescoping will need TS - I just turned this off too.
I also disabled the "Add Foot AIR in Face mode".
Go into Settings/Vehicle Customization/Other and find the Easy Entry Seat.
Change it from Full to Partial and the wheel will move but the seat will move less.
Off will defeat any movement of the seat and the steering wheel.
A lot of great info in this thread. Here's my contribution.
One press of the traction control switch turns off the Traction Control (TRAC). Pressing and holding the switch turns off the Vehicle Stability Control (VSC).
