Anyone use non OEM AIR FILTER FOR GX 460?
Old 07-20-16, 02:27 PM
ejn184
ejn184's Avatar
Default Anyone use non OEM AIR FILTER FOR GX 460?
just wonder, if any one use non oem air filter , like afe or k&n?
ejn184 is offline
Old 07-20-16, 03:33 PM
tecman
tecman's Avatar
The K&N has been in my truck for about 40+K miles. Time to do the cleaning process or just replace it. The K&N filter is a touchy topic in this forum
tecman is offline
Old 07-20-16, 04:20 PM
Eppieguy
Eppieguy's Avatar
I use a K&N in mine as well.
Eppieguy is offline
Old 07-20-16, 04:42 PM
tecman
tecman's Avatar
I will order the cleaning kit.
https://www.clublexus.com/forums/gx-...new-gx460.html
tecman is offline
Old 07-21-16, 03:19 AM
pinoyesv6
pinoyesv6's Avatar
I've had the dry AFE in my car for 15k now with no issues. Since it is a dry filter, whenever I have the hood open (which isn't that often) I will take the filter and tap on it to knock out the larger particles of dirt.
pinoyesv6 is offline
Old 07-21-16, 07:40 AM
Rhinetom
Rhinetom's Avatar
Hello, I added a WIX filter and it dropped right in. Any filter that you have to periodically oil seems like a huge hassle to me
Rhinetom is offline
Old 07-21-16, 11:46 AM
GoHuskers
GoHuskers's Avatar
Can you share the part number?
I had K&N in my Taco and I believe it caused the truck to run RICH...I see black residue on the tail pipe (and rear bumper/quarter panel) after 10k miles....I threw it away.
GoHuskers is offline
Old 07-21-16, 11:55 AM
pinoyesv6
pinoyesv6's Avatar
Its the same part numbers as the one for the FJ Cruiser and the 4Runner
31-10208
Old 07-21-16, 01:55 PM
coolsaber
coolsaber's Avatar
k&ns are good for those who appreciate delicate balances. If your want to set and it forget it, just buy the regular ole filter and call it a day. No power gains or such, as the motor is tuned optimally to the air box
coolsaber is offline
Old 07-25-16, 05:47 AM
Craig B
Craig B's Avatar
Not a good idea to tap the air filter to let dirt out, it will suck up loose dirt, change the filter.
Craig B is offline
Old 07-25-16, 06:21 AM
pinoyesv6
pinoyesv6's Avatar
Not sure I quite understand.
Tapping the filter on the ground is one of the first step to cleaning the filter according to my filter's manufacturer. I am not tapping the dirt into the filter, im tapping it out. If I knock dirt loose and it gets sucked back into the filter for some odd reason, the filter is going to stop it from going into the engine like it the first time.
Old 07-25-16, 05:22 PM
tecman
tecman's Avatar
I should have checked it at 20K or so. Now I know to spin the filter due to the intake location. The filter is perfectly square so this would help no matter what filter you have.
tecman is offline
Old 02-14-19, 06:52 AM
Ramacher
Ramacher's Avatar
Sorry to revive an old thread but how long does it take for the filter to dry out before reinstalling after cleaning it?
I visit a lot of job sites that are off road and very dusty and think I need to switch out to a K&n filter.
Ramacher is offline
Old 02-14-19, 10:42 AM
tecman
tecman's Avatar
Directions say to gently shake off excess water and underlined allow filter to dry naturally.
I don't recall how long it took but temperature would be a factor.
tecman is offline
Old 02-14-19, 10:47 AM
Ramacher
Ramacher's Avatar
Ok, I'm thinking I'll get the k&n and keep the current stock filter (or buy a new one) and use it for a day or so when the K&N needs cleaning.
Ramacher is offline
Quick Reply: Anyone use non OEM AIR FILTER FOR GX 460?
