Off Roading
Old 12-30-17, 01:38 PM
  #106
Acrad
Super Moderator
Acrad's Avatar
Received 3,637 Likes on 2,383 Posts
bbqsoup (12-30-17)
Old 12-30-17, 01:54 PM
  #107
tecman
tecman's Avatar
^^ Pretty good video but crappy music choice
Old 01-01-18, 07:34 AM
  #108
kroorda
kroorda's Avatar
Default crawl control
Originally Posted by Acrad35751
So crawl is 5 different speeds? FSM seems to suggest that. I assume DAC on "non-crawl" models is basically a fixed speed downhill crawl control. I've used it a few times on steep hills. There is mention in FSM about overheating issues if used for extended periods of time.
Crawl Control - 1 to 5 MPH
DAC- appears to be around 3 MPH
You can use Crawl Control while in any gear, but normally, it would only be used in first gear as first gear would give you the most control and 'crawl' with it.
Old 01-01-18, 04:07 PM
  #109
Acrad
Super Moderator
Acrad's Avatar
You have the full Driver Support Package on yours?
https://www.clublexus.com/forums/gx-...l-control.html
For crawl control if it was just a BCM and console switch swap like in the 4Runner...might be something for me to think about.. not positive a new master cylinder is needed though. I notice '10-'13 they had standalone crawl available as an option but I can't say I've seen that unicorn. That might be rarer than the GX's without nav.
This guy retrofitted his '15 4Runner
http://tctmagazine.net/spring-2016/2...ntrol-retrofit
Old 01-01-18, 04:20 PM
  #110
Acrad
Super Moderator
Acrad's Avatar
Older video from 2010 showing KDSS comparison of 150 series to 120 series, Discovery and Mitsu Pajero
Old 01-04-18, 10:16 AM
  #111
bbqsoup
bbqsoup's Avatar
Wow! I applauded him for doing this. Alot of admiration for people that modding the vehicles to do what they want. Pretty cool to read.
Old 01-04-18, 01:53 PM
  #112
tecman
tecman's Avatar
Acrad (01-04-18)
Old 01-04-18, 03:34 PM
  #113
bbqsoup
bbqsoup's Avatar
I would have wash the seat afterward... pucker factor
Old 01-04-18, 03:57 PM
  #114
Acrad
Super Moderator
Acrad's Avatar
Originally Posted by tecman
Nice video!!
Looks like at ~1:45 he put in 4L and possible center diff to utilize ATRAC. For those that don't know... keep under like 2200RPM or so for ATRAC to work best.
Old 01-04-18, 03:59 PM
  #115
Acrad
Super Moderator
Acrad's Avatar
Just speculation but I don't think splicing would be necessary on the GX... just a console with the crawl switch on it. There were some physically absent switch assemblies on the 4Runner.
Old 01-06-18, 11:05 AM
  #116
kingtux
kingtux's Avatar
Are you saying that the wiring could potentially be there and all that would be needed is the switch installed??
Old 01-06-18, 11:39 AM
  #117
Acrad
Super Moderator
Acrad's Avatar
That very well could be.... I've thrown this out there to give thought to the adventurous souls who want to travel the path first :-)
At minimum a new switch and a BCM. The big expensive if....is if a different master cylinder is needed. The BCM new is not too bad at around $500...used probably half that. The 4Runner guy didn't need the master cylinder replaced.
Some more info I posted in a different thread.
If all the connectors on the wiring harness side of console switch are terminated in the connector then a major piece is already done.
Old 01-06-18, 02:38 PM
  #118
kingtux
kingtux's Avatar
Looks temping 😁 , has anyone called the dealer on this?
Old 01-14-18, 11:07 AM
  #119
Nickk6
Nickk6's Avatar
Nice video!!
Hah, sorry guys looks like you found my video. I actually deleted it since it was 5 minutes, here is the shortened one. Yeah I put it in 4 low because it was very off camber and it would have just spun in 4hi
Another trip yesterday
Still getting the hang of the drone.
The following 3 users liked this post by Nickk6:
FinDiesel (08-14-18), nyctfl (05-23-23), tecman (01-14-18)
Old 01-14-18, 11:14 AM
  #120
tecman
tecman's Avatar
Nice, thanks
Quick Reply: Off Roading
