"What did you do to your..." thread?
cploy (10-10-20)
The following 3 users liked this post by klinquist:
#875
@klinquist
are you going to be running lockers? Ive always wanted to get an ARB compressor but I would only use it to pump up tires.
#876
@klinquist
The best locker solution for our trucks seems to be the Hadoop e-locker, not an air locker.
#877
Nope, this will only be used for tires (mostly re-inflating after airing down for offroad & snow). I also haul a dirt bike around and am constantly using an air compressor to air that up & down, so this will be nice.
have you thought about the wifey system?
https://www.ragofabrication.com/prod...fey-air-system
RoyGBiv (10-11-20)
#880
This weekend I...
* Dremeled out the OEM fog light holes and stuck some Baja Designs S1s in there.
* Installed a fire extinguisher using a bracket I found on eBay that says it fit the 5th gen 4R/FJ Cruiser.
* Replced the center shift panel - mine was scratched to hell when I bought the car and it bugged me.
The following 4 users liked this post by klinquist:
#881
@klinquist
Do you have a link or any more info on that fire extinguisher bracket? How's the clearance between the person sitting and the extinguisher handle?
#882
@klinquist
Passenger leg clearance is fine.
This does limit the forward slide of the seat a bit.
ObsidianBl (09-21-20)
#883
I added some Amazon purchased cross bars today. Seems fairly sturdy as I put them on the floor and stood on them @212lbs.
Diking Roof Rack Cross Bar 2010-2020 for Lexus GX460 Crossbars OE Style #PT278-60091
bbqsoup (10-07-20)
#885
Installed the OEM 'sport design' smoked tail lights.
I was thinking of buying the fancy ones from Dubai, but after reading about the gap at the bottom... and moisture getting inside of them... decided OEM was the way to go.
