GX 460 Tow Package - Brake Control
Old 09-10-17, 11:28 AM
raynyc
raynyc's Avatar
i dont but i think they are aluminum so maybe 100-1500 lbs , thats good advice on the sport mode
Originally Posted by Acrad35751
Do you know how much the trailer weighs? It should handle that fine though.
I put it over in Sport mode and keep in 4th on the tall grades.
Old 09-10-17, 11:30 AM
Acrad
Super Moderator
Acrad's Avatar
Received 3,641 Likes on 2,385 Posts
I towed that amount last week over a pass... mileage was like 12 or 13 MPG but I was heavy on pedal too. Lots of additional wind drag on trailer I was pulling as well.
raynyc (09-11-17)
Old 09-10-17, 10:18 PM
bigphil001
bigphil001's Avatar
I tow a 20' enclosed trailer with a race car inside of it on a regular basis and the GX does great!
The following 8 users liked this post by bigphil001:
Acrad (09-10-17), cancruiser (01-05-22), cridel (08-01-22), IanB2 (04-27-21), JoshDrivin (08-14-20), raynyc (09-11-17), sinistar (05-27-20), Tessie (09-19-17) and 3 others liked this post. (Show less...)
Old 09-11-17, 07:06 PM
Acrad
Super Moderator
Acrad's Avatar
How much do you think you are pulling?
Old 09-11-17, 07:15 PM
bigphil001
bigphil001's Avatar
The cat scale at the local truck stop says 6350 lbs.
raynyc (09-12-17)
Old 09-12-17, 02:58 PM
Acrad
Super Moderator
Acrad's Avatar
That is a nice solid showing of the GX's capabilities.
Old 09-12-17, 03:31 PM
bigphil001
bigphil001's Avatar
I did invest in a very good weight distribution hitch, and the trailer has good brakes.
No problems cruising on the highway at 70 mph.
Old 09-19-17, 03:19 PM
Acrad
Super Moderator
Acrad's Avatar
Misc eTrailer post on brake controller install on GX
https://www.etrailer.com/question-76352.html
Old 09-21-17, 04:10 PM
Acrad
Super Moderator
Acrad's Avatar
Old 09-21-17, 04:21 PM
joindy
joindy's Avatar
Default GX 460 Brake controler
Just bought 2014 GX with factory hitch. If you have factory hitch they put a 6 in long cable in the glove box, which is a Toyota cable that pugs into your wiring under the dash {wiring for lights}.....on drivers side...which can then be wired to a controller, I had a P3 in my Tundra and kept it to reinstall. The connector is for Toyota./Lexus only. If you don't have the cable it is under $10...can buy at dealership, Amazon etc.
Old 04-25-18, 08:22 AM
wpelfrey
wpelfrey's Avatar
I tow a travel trailer (camper) that weighs about 3600lbs with my 2012 GX 460. It has gone pretty well. Anyone install a transmission cooler to their Lexus, or any other parts for towing (other than tow hitch and trailer brake)? Thanks.
Old 04-25-18, 08:47 AM
bigphil001
bigphil001's Avatar
The GX has a transmission cooler straight from the factory.
https://www.clublexus.com/forums/gx-...ny-cooler.html
wpelfrey (04-25-18)
Old 04-25-18, 10:42 AM
wpelfrey
wpelfrey's Avatar
Thanks for the quick response. I see the trans cooler on the diagram. It looks small. Do you think an additional trans cooler, installed in front of the radiator, would be helpful? I was parking my trailer at a camp site this past summer and got a warning on the screen behind the steering wheel that my transmission fluid was getting dangerously hot. I parked the camper, then let the Lexus cool off. I took it to the dealership and had them change the transmission fluid. I'm just worried about a future overheating transmission. Thanks for the help.
Old 04-25-18, 12:26 PM
Acrad
Super Moderator
Acrad's Avatar
It would help. I think it would take a very large cooler for it to be a problem.
There are a number of aftermarket units available.
Here is a mount that KAON sells. The top two screws are the same holes used for the horn if you go with an aftermarket.
https://www.kaon.com.au/store/p3/Pra..._Brackets.html
The OEM one they sell on GX's in Canada use this one.
3291060170
wpelfrey (04-25-18)
Old 04-25-18, 05:16 PM
wpelfrey
wpelfrey's Avatar
Thanks for the quick response. Looks like that trans cooler would help the engine, especially if I am towing in hot weather. Do you think I should get that installed at a Lexus/Toyota place, or could most repair places do that kind of work? I appreciate the advice.
Quick Reply: GX 460 Tow Package - Brake Control
