How do you disable dash lights after removing air suspension/AHC?
Old 08-26-21, 04:51 PM
  #76
Acrad
Super Moderator
Acrad's Avatar
Received 3,652 Likes on 2,391 Posts
You shouldn't get any lights or notifications on the dash. If you run a full Techstream or OBDLink scan you will find codes related to the missing shocks but just a side effect of removal.
Hehena (08-26-21)
Old 09-11-21, 07:56 PM
  #77
shep6924
9th Gear
shep6924's Avatar
Default Similar air issue
I did a airbag to coil-spring conversion and I could hear the air compressor running when I checked the height adjustment switch. I haven't attempted to remove power or fuses, but I am concerned the motor will eventually burn out and I'll end up with errors. Did anyone come up with a fix?
Old 09-12-21, 08:44 AM
  #78
Acrad
Super Moderator
Acrad's Avatar
Were you trying to manually adjust the suspension?
If you have suspension set where it isn't normally going off you could always look at de-pinning the connections to the console switch for the suspension.
Unfortunately the closest I have seen to compressor delete was a member of GXOR who gutted the motor of the compressor motor itself but left all of the other compressor electrical intact. I never heard specifics of what he did though to the compressor.
Removal of fuses or relays will result in errors though.
Old 09-12-21, 09:31 AM
  #79
shep6924
9th Gear
shep6924's Avatar
I'll look at pulling the pins, thanks!
Acrad (09-12-21)
Old 12-20-21, 04:32 PM
  #80
dooglaz
dooglaz's Avatar
After removing the air suspension, doing the spacer trick, and putting in crawl control (with no air suspension controls), I had no error messages, but I did hear the compressor from time to time. I have no idea how often it was running but I noticed my battery getting lower over time. It was time to get rid of the compressor!
Here’s the deal- you can remove all of it, just not the solenoid. It was a pain, but the compressor is out, the solenoid remains, and everything is working well. The only image I could find for the job was the stock image below so I’ve added some of mine. You can see what was removed and what remains.
I could have removed more things (lines, etc.) but I didn’t bother. The good news is that I won’t hear the air compressor again because it ain’t there. 👍🏼
The following 2 users liked this post by dooglaz:
Acrad (12-20-21), Hehena (12-21-21)
Old 12-20-21, 04:49 PM
  #81
Acrad
Super Moderator
Acrad's Avatar
Thanks you!
A few have reportedly done this over the years but never documented to this detail.
Old 01-12-22, 02:05 PM
  #82
Acrad
Super Moderator
Acrad's Avatar
GXOR member reported this to get rid of the compressor
http://www.facebook.com/groups/Lexus...09801942484238
nuclearn8 (01-13-22)
Old 06-25-24, 10:32 PM
  #83
EverD
4th Gear
EverD's Avatar
@EverD Have you tried this? Do you still have your height sensor? This can reportedly address the air pump
https://www.clublexus.com/forums/gx-...l#post11202694
I had the shop who did my lift try the 5phm resistor trick and it still throws rhe code. I was going to just try and pull the relay off the air pump and hook it up to see if that will clear it. Haven't had the time to try it,.
Old 06-26-24, 03:51 AM
  #84
Acrad
Super Moderator
Acrad's Avatar
Did you leave the height sensors in place? I haven’t seen any tricks to remove those entirely but only modified.
What specific codes are you pulling with with Techstream or OBD Link?
mlees
GX - 1st Gen (2003-2009)
01-31-17 07:36 PM
dak244
12-17-16 12:02 PM
Evoking
GX - 2nd Gen (2010-2023)
06-23-15 09:32 PM
R3loader
09-17-13 10:03 PM
Quick Reply: How do you disable dash lights after removing air suspension/AHC?
