View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2011 - Base - Added Crawl
0%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Premium (stock Crawl) - Added MTS
0%
2014 Base - Added Crawl
0%
2015 Base - Added Crawl
0%
2015 Premium - Added Crawl
0%
2016 Base - Added Crawl
0%
2016 Premium - Added Crawl
0%
2017 Base - Added Crawl
0%
2017 Premium - Added Crawl
0%
2017 Luxury - Added Crawl/MTS
0%
2018 Base - Added Crawl
0%
2018 Luxury - Added Crawl
0%
2019 Base - Added Crawl
0%
2019 Premium - Added Crawl
0%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
Voters: 124. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
Super Moderator
EDIT: I am curious if someone without Intuitive Park Assist has this module. It's a really easy check.
I was looking inside the glove box and noticed there is a removable panel on the left. I pulled off and there is a module there. Now...this module may need to be replaced with the "020" version but seems to be pretty easy to get at assuming the glove box is easy to remove. Looks like most I've worked with that has like 5-6 screw. Not sure if front passenger soft trim or anything lower needs to be removed to remove glovebox. I need to check FSM.
r2m (02-01-19)
Look at drive control diagram. DAC and Crawl Control seems on the same connector and EUC seems already in the car since its combined with other basic function such as traction control, etc. Maybe it is just a plug-N-play with different switch panel.
Acrad (01-27-18)
Super Moderator
I am starting to lean with that thought myself...
Super Moderator
No kidding... extended test drive ;-)
It would be a quick test to see what happens.
Cough.... Extend test drive.... cough..... or..... Turo cough cough. Kidding
The google translation made it seem it was just plug and play. But I can’t say for sure since I haven’t taken anything apart. Maybe there is some hope for my heated steering wheel.
Crawl control and multi camera would be a very nice addition. Not too interested in lane departure or radar cruise.
Super Moderator
Finding a used switch might prove difficult since relatively rare option.
Here is a place in Dubai that has it for $190.70 + whatever other charges are involved.
https://carmarka.com/en/search/index?q=84970-60070
Super Moderator
Looks like a continuation of discussion about this on a Prado forum in Russia.
http://www.prado-club.su/forum/index...ic=118048.1080
Super Moderator
Possible an ABS reset with Techstream. This is from the 4Runner retrofit.
Latest forum link above I see them doing this reset procedure.
http://www.prado-club.su/forum/index...ic=118048.1210
Super Moderator
Someone with a Prado just converted with a button here. Strong evidence of 020 module needed. I think I will see if I can read any numbers off module with my inspection camera. First guy was plug and play...may have already had 020 from factory. The second one replaced module and installed switch.
https://www.drive2.com/l/477106683668070625
https://www.drive2.com/l/2499065/
Super Moderator
I just looked as well with my camera. One would need to pull glovebox. That module is surrounded in it's bracket so I couldn't see any version numbers.
Looks like there are five different revs
Super Moderator
Here is some date info on modules listed above.
https://toyota.7zap.com/en/eu/land+c...84b052e/#859A1
https://www.mylparts.com/?p=catalog&...20DRIVING%20SU
Super Moderator
The module in that bracket that I might be looking at is the telematic transceiver. I think module might be the one on the left where two sit side-by-side.
Glovebox removal
Probably not a good time for me to tear into my dash right now and need to do an oil change on my G35x tomorrow.
Glovebox removal
hzhao (01-27-18)
