High Beam LED replacement...
Old 11-29-18, 04:52 PM
  #76
John00
John00's Avatar
Originally Posted by tecman
^^^ Sorry editing complications
That is a small bulb, I don't think ANY led in there would melt anything. I have LEDs there and they run cooler than halogen.
Here's two designs that melt:
They only run cooler when the dissipation is good enough to take away the heat and add it into the air. The first one will be obvious right away, the second one will take some time. The second one is notorious for claiming and not having a zener.
Old 11-29-18, 04:56 PM
  #77
John00
John00's Avatar
Quick search for overheating and the first one that popped up was that top design.
In many cases, its the false CANBUS stuff.
https://www.tacomaworld.com/threads/...uccess.438288/
Any bulb you might think about for continuous use should be verified as OK for continuous use. I've tested many and a lot of them melt. Well known name brands won't, but the generic stuff does sometimes.
Old 11-29-18, 05:01 PM
  #78
tecman
tecman's Avatar
What is the solution John? What are you running that won't melt and smoke? LEDs can be purchased cheap and we have VLEDs and other brands that are expensive and that is most of what I have in my GX.
Old 11-29-18, 05:06 PM
  #79
tecman
tecman's Avatar
Always wondered why these were so cheap and bright and I do have some in my GX.
Amazon Amazon
Old 11-29-18, 05:09 PM
  #80
John00
John00's Avatar
For the side marker I use
Old 11-29-18, 05:14 PM
  #81
John00
John00's Avatar
that marker by itself, front view
that marker, angled view to see both front and through yellow piece, with HIDs on (35W Ultinons 6k)
I looked at a past post realized I didnt say which I was using as a marker so I went to look at the package and snap some pics.
Old 11-29-18, 05:25 PM
  #82
John00
John00's Avatar
Here's the brightest bulb I use in that style:
Amazon Amazon
I only use for intermittent use, but it might be ok for continuous, although it would be too bright. I have this one for my puddle lights and for the rear two lights just inside the barn door.
seriously, it is brighter than you can imagine, has an aluminum body to move the heat. Removing the CANBUS resistor on many LEDs would eliminate the heat problem.
The resistor is not CANBUS in any way CANBUS is a protocol and that resistor is just to fool any current monitoring that may be in the car (2012 GX doesn't have this for any 5w bulbs)
Old 11-29-18, 11:33 PM
  #83
konc3pt
konc3pt's Avatar
Location: From Oakland to Sactown, the Bay Area & backdown
Wonder what it would look like with red or blue bulb in there
Old 11-30-18, 05:46 AM
  #84
John00
John00's Avatar
Someone throw in an RGB 194. Those colors on front would get those colors in back where I live.
Old 11-30-18, 05:55 AM
  #85
John00
John00's Avatar
Hi level solution is to get bulbs with proper heat management for the use.
Low level solution is to perform bench testing on any bulb that if melts would cause too much hassle. Hook the bulb to a power supply at 14V, lets the temp reach steady state, then decide on putting it in the car's enclosure. A laser thermometer is nice to have. Each diode can have different max junction temp ratings, but most I've seen stay below 150C and I'd prefer 120C or less. Anything over 1/2 the solder reflow temp can have long term issues, most reflows are around 220-240C.
Small bulbs not from major well know manufacturers are usually the culprits in quicker more violent death. Large bulbs with fans or fins usually don't have immediate problems.
Test the bulbs on a bench, then use them in the car. Don't test them in the car. The last thing we want is a nice layer of melted nastiness on the inside of a lamp housing (think smoke damage) that could have easily been prevented.
Old 11-30-18, 10:45 AM
  #86
konc3pt
konc3pt's Avatar
Likely same here, might put amber color bulb there...do I need to remove the entire light assembly to get in there ?
Old 11-30-18, 05:16 PM
  #87
John00
John00's Avatar
No. it's a tight fit but you can manage without removing the light assembly.
RGB 194 pair, <3$ shipped, shows blue-ish color mode.
konc3pt (12-01-18)
Old 12-01-18, 01:13 AM
  #88
konc3pt
konc3pt's Avatar
good deal, ordered a set
Old 12-01-18, 05:26 AM
  #89
John00
John00's Avatar
Let us know how hot it gets after a while on a bench 14VDC test. Those look like the cooler old style LEDs, they're hard encapsulated, then the entire assembly is encased (catches potential smoke). Most likely no heat issue, just curios. Also, is it an IR remote and how well does it work through the housing, side reflector, etc.?
Old 12-03-18, 01:27 AM
  #90
konc3pt
konc3pt's Avatar
Will do, thanks for your help and information. Do I need to get a set of LED DRL Decoders to get them to work ?
Quick Reply: High Beam LED replacement...
