Aftermarket Parts for '10-'13 Premium / 14+ Luxury with AVS and RAHC
I'd be too nervous using those in terms of product longevity.
Does anyone have the actual part numbers for the adjustable front and rear shocks to price them out for OEM replacements from a reputable vendor?
Seems like the front is maybe 48510-60260 at $281 a piece, rear is 48530-60260 at $540 a piece and those are from a discounted OEM vendor.
I'll need to evaluate my shocks here sooner than later. Vehicle still rides all right, but eventually I would like to do a refresh. Since it's my wife's vehicle, I don't want to do a lift and I don't really want to use the non-premium shocks, even though they are cheaper. Even at $1600 or so, that's not bad... plus labor of course. The rears seem easy enough, I'd probably have a local Lexus/Toyota off road place do the fronts.
Super Moderator
Rears seem to be easy to replace. I'd probably soak those small hex screws on front AVS actuators with some PB Blaster for several days.
Super Moderator
I think mine are fine as well but would just play extra safe on those small 4-5mm hex screws. IIRC... there is always the stabilizer bar tension w/either a floor jack or the KDSS release procedure to get the front shocks off.
Super Moderator
While the shocks I am on the fence ...I'd entertain aftermarket bags. Compressor is another one I am on the fence... my Timbrens's give me some flexibility if compressor fails and suspension heads toward the bump stops.
Pics from Timbren thread.
Stock
versus Timbren
Stock
versus Timbren
Super Moderator
A 470 package but first I have seen of these bundled packages. $450
- Quantity: 5 Piece Set
- Kit Includes:
(1) Air Suspension Compressor
(2) Ride Leveling Height Sensors
(2) Rear Air Springs
Super Moderator
I've heard really good things about the Arnott bags if one wants OEM level quality and a lifetime warranty. Still not cheap but about ~$125 less than OEM--> $362 versus $488
"Arnott LLC® offers a Limited Lifetime Warranty for United States and Canada on Arnott branded Air Springs, Air Struts, Compressors, Coil Spring Conversion Kits and Arnott branded Adjustable Motorcycle Suspension Kits."
https://www.arnottindustries.com/pro...er/gx-460/2018
Right
https://www.arnottindustries.com/pro...0-4runner-n280
https://www.summitracing.com/parts/ntt-a-3331
Left
https://www.summitracing.com/parts/ntt-a-3332
Right
Left
Super Moderator
Super Moderator
I have heard a fresh cut on the air line is beneficial with a tool like this during bag replacement.
Far less RAHC 460s than on 470s due to it not being a standard option. I know someday I will be replacing bags.
Romanova (10-07-21)
Super Moderator
Right
Left
Right
Left
Fast forward a couple years, the OEM ones are $818 and the Arnott ones are $440. EACH! WOW.
A shop near me who specializes in Toyota, Lexus, and Scion says the Arnott ones are far worse, they see a lot of failures with them.
With that said, the Arnott ones are still cheaper and have lifetime warranty. I wonder how easy the install would be if I DIY without a lift? Any videos? Also, how much harsher is the ride with the Arnott ones?
Wow. I’m so glad I picked up a full set of front and rear suspension parts from a luxury 2021 to keep as spare.
Super Moderator
