Breather mods
Breather mods
I haven’t seen any posts regarding rear diff breathers. Is this necessary for the GX, similar to the other Toyota suvs and trucks? I remember seeing this pop up on the 5th gen 4Runner forums.
I don’t have any current plans to go all out modifying the GX... yet. This may be useful for those that are heavily modifying the vehicles.
http://www.toyota-4runner.org/5th-ge...-complete.html
http://www.toyota-4runner.org/5th-ge...d-dummies.html
Acrad (03-28-18)
Good thread to start....
I posted a few hits in this thread as well
https://www.clublexus.com/forums/gx-...ing-depth.html
There's a breather vent on the top of the rear diff (offset to the driver side IIRC) but it's not routed up high in stock form. Pretty simple mod to add some tubing and extend the breather up to the rear control arm or following the fuel tank filler tube (that's what I did on my 80).
Edit: This is the part I used on my old Tacoma which I bet would still work with the GX: 90404-51319. Install it on the diff, then some 3/8" fuel line up to a high spot, then the breather vent on the top. You could re-use the vent on your axle right now, or buy a new one.
Acrad (03-28-18)
Here’s some more info from a GXOR member who did the rear diff mod
https://m.facebook.com/groups/838842...omment_mention
Acrad (04-10-20)
I've seen both fuel hose sizes used on the 4R forums.
I think the following recommends 5/16"
PN: 90404-51319
PN: 90930-03136
Transmission & Transfer Case breathers apparently terminate up against the firewall behind engine somewhere.
PN: 90404-51319
PN: 90930-03136
