Side Mirror Problems/Repairs/Questions
Old 10-11-11, 05:16 AM
Tnorling
Tnorling's Avatar
Lightbulb Side Mirrors during Reversing
Is there a way to disengage the side mirrors from turning downward during the reversing process?
Last weekend, I found it very difficult to see my JetSki trailer while backing down the boat ramp.
And no, the monitor does not help in this situation.
Thanks!
Old 10-11-11, 07:42 AM
gs400jon
gs400jon's Avatar
Put the mirror switch in the middle position.
EJC (04-21-22)
Old 10-11-11, 04:22 PM
rs/ss
rs/ss's Avatar
seems counter intuitive but that's what you gotta do.
EJC (04-21-22)
Old 10-12-11, 07:30 AM
russcarver
russcarver's Avatar
Yeah, Nissans have the same "feature". Switch in the middle position is the trick. Moving it to either side causes that mirror to angle downward so you can see the curb and your tire while parallel parking. It also lets you see any toys the kids may have left in the driveway before you back out of the garage (that aren't directly behind the vehicle).
--Russ
Old 10-12-11, 07:43 AM
Koz
Koz's Avatar
The reason the tilt down operates when the switch is in the left/right position is so that you can adjust the mirror in the tilted position. Sometimes you may need to look down further.
Koz
Old 10-13-11, 08:29 AM
MickeyS
MickeyS's Avatar
If you adjust the mirrors while they are down, would that affect the mirrors when they are not down?
Old 10-13-11, 08:54 AM
Koz
Koz's Avatar
I don't think it does (I will check) but you can always hit the memory setting.
Koz
Old 10-24-11, 05:16 PM
Koz
Koz's Avatar
Koz
After adjusting the mirrors when tilted down they returned to the original position when put back in drive.
Koz
Old 01-23-12, 03:00 PM
dongluk
dongluk's Avatar
Default side mirror replacement
Does anyone know how to disassemble the side mirror of GX460? I heard that it just clip-on ,but it's hard to take off. Thanks.
Old 01-23-12, 04:17 PM
rockydog
rockydog's Avatar
Check here for drawing:
http://www.mylexparts.com/parts/2010...iagram=8942500
Old 01-23-12, 04:37 PM
dongluk
dongluk's Avatar
Originally Posted by rockydog
Thanks alot. it helps. I bookmarked it already.
Old 02-19-14, 10:19 AM
jblackfish
jblackfish's Avatar
Default Mirror signal light lens replacement help needed.
I and my 2011 GX460 are new to the forum. I don't know if I should have asked this in Lighting, Maintenance or here so please forgive if it's the wrong place.
I have a small BB hole in the right mirror signal light lens - the person I bought it from is sending me the part (it may be an assembly) and I should have it tomorrow but I don't know how to go about removing/replacing the lens. Can anyone help?
Old 02-19-14, 11:11 AM
Eppieguy
Eppieguy's Avatar
Welcome Aboard!!
I don't know that it's ever been discussed but hopefully the part will show how the original one is clipped in there. Let us know.
Old 02-20-14, 08:31 AM
T4Fun
T4Fun's Avatar
the lexus dealer charges about 200 for this job.
its not easy to open the whole side mirror jig up.
Old 02-24-14, 04:31 AM
jblackfish
jblackfish's Avatar
Thanks for both replies - I've looked at it carefully and it doesn't look like an easy job for an amateur. If I could take the mirror out I think it'd be a fairly easy install but I don't see an easy way to get at it. I'll probably take it to a dealer a bite the (cost) bullet.
Quick Reply: Side Mirror Problems/Repairs/Questions
