#Intuitive #Parking #Assist & sensor questions
Old 04-30-20 | 05:34 PM
  #151
Saul1's Avatar
Saul1
Great! will do.
Thanks guys
Old 04-30-20 | 07:36 PM
  #152
coolsaber's Avatar
coolsaber
Originally Posted by Jacket
The additional PN digits after the first 10 (like C2 or C4) are usually color or trim differences. Probably won't match in color - assuming the part is exposed through the bumper. But I bet it fits the wire harness and retainer. Let us know.
Ih8Mud mod with the insight! Thanks.
I always thought those additional numbers were revisions
Old 04-30-20 | 07:50 PM
  #153
Acrad's Avatar
Acrad
Super Moderator
I have the listing here. A few I’ve not been able to match yet
https://www.clublexus.com/forums/gx-...t-numbers.html
Part number suffix and paint color codes:
A0 - Starfire Pearl
B0 - Tungsten Pearl
B1 - Knight's Armor Pearl
B2 - Nebula Gray Pearl
B3 -
B4 -
C0 - Black Onyx
D0 - Claret Mica
E0 - Satin Cashmere Metallic
E1 - Fire Agate Pearl
G0 - Peridot Mica
J0 - Nightfall Mica
••Still Need to place "Silver Lining Metallic" and "Atomic Silver" as one of these or additional paint code.
B3 - Platinum Silver ME
B4 - Sonic Titanium
Old 05-09-20 | 08:21 AM
  #154
dwh13's Avatar
dwh13
So for anyone else with this issue, turns out it isn't a loose connection. The issue came back after a few hours of driving. I ordered a replacement ECU from a wrecked GX and am getting the same results - it works intermittently, but out of nowhere will throw that error message. My Carsoft Toyota scan tool detects the ECU but says there are no error codes. The only thing I can think of is an issue in the wiring, and it's just not something I care to dig into any further unless anyone has any ideas?
Old 05-09-20 | 08:27 AM
  #155
Acrad's Avatar
Acrad
Super Moderator
I know it isn't throwing codes and I haven't looked at connector recently but have you thought about swapping sensor locations to see if it problem follows going from the middle to a side location or back? It might be easier to swap middle front to middle back as the side ones are differently shaped IIRC.
Old 05-09-20 | 08:29 AM
  #156
dwh13's Avatar
dwh13
I thought about that, but the FSM says that it will call out the malfunctioning sensor on the screen. When mine acts up, it just says park assist error and all of the sensors light up.
Old 05-09-20 | 08:41 AM
  #157
Acrad's Avatar
Acrad
Super Moderator
Sorry..... I forgot to look further up in the thread at the pictures you posted.
I notice your OBD reader says "Intelligent Parking Assist" ---> Without
Is that a detection from a vehicle or user prompt to select? Just curious if your reader isn't fully reading the ECU.
I know OBD Fusion sees the KDSS ECU but no PIDs within it.
Old 05-09-20 | 08:45 AM
  #158
dwh13's Avatar
dwh13
That's a detection from the vehicle - I'm assuming that's the surround camera system. When I unplug the parking sensor ECU, "Curr Com Clearance Sonar" changes to "Without" so that's definitely the right one
Old 05-09-20 | 09:02 AM
  #159
Acrad's Avatar
Acrad
Super Moderator
Like you saw FSM really only lists replacement of that ECU you already replaced so may be wiring.
Another thought... I think that dash message is the generic error that shows up for all issues even if it was just one sensor. Seeing that the nav screen is showing front center might still be worth looking at swapping some sensors front to rear.
EDIT: I stand corrected. It does show specific sensor in FSM on warning in gauge cluster.
Old 05-09-20 | 09:38 AM
  #160
Acrad's Avatar
Acrad
Super Moderator
If you have a Techstream install setup you may want to see if everything is being detected correctly in the data list for ECU. This may help isolate the area of the system to look at if it is wiring.
Old 06-08-20 | 05:29 AM
  #161
barrysl's Avatar
barrysl
Default Rain causes front emergency sensors to go haywire on my 2019 RX450h Fsport.
Yesterday I drove in the pouring rain for 45 minutes and my sensors did not react through the storm. I was quite surprised and said to myself it's just one of those things. Thanks everybody for your responses b a r r y s l
Old 03-27-22 | 12:12 PM
  #162
FixAndSave's Avatar
FixAndSave
5th Gear
Default How to Replace Lexus GX 460 Parking Sensor!
Hey everyone,
We made a video on how to replace a parking sensor for a Lexus GX 460, check it out and let us know what you think!
The following 4 users liked this post by FixAndSave:
Acrad (03-27-22), BillWill87 (04-13-22), hzhao (03-27-22), tntcandy (03-27-22)
Old 08-24-22 | 10:26 PM
  #163
alexhjs's Avatar
alexhjs
3rd Gear
Default Please help! 2011 GX460 - Which parking assist sensor is this?
New to the GX world and the forum as well. Just trying to troubleshoot Check Sonar System and I am slowly finding out perhaps its not my dynamic cruise control that is a problem but rather one of my park assist sensors at the front?
Please see the attached photo. I understand that there are 4 sensors at the front of the 2011 GX460s but the error message/picture shows a sensor at the front DEAD in the centre.
All I see in the center of the front is my front camera which is functioning. Is there another sensor there that I am unaware of?
Old 08-24-22 | 11:09 PM
  #164
alexhjs's Avatar
alexhjs
3rd Gear
Hey guys, which parking assist sensor would it be for dead centre in the middle at the front?
please see the attached photo. Vehicle is a 2011 GX460.
Old 08-24-22 | 11:37 PM
  #165
JonGX's Avatar
JonGX
are you looking for a part number?
partsouq.com is about as easy as it gets
