Rear window/hatch rusted strut mountings
#33
Have the same issue here too! Really annoying. If you find part numbers, please share with us.
i wonder if lexus would cover this under their corrosion warranty up to 72 months.
nuclearn8 (11-22-19)
#36
2016 GX Rear Window Piston Hardware Rusting
Cheers - I just bought a 2016 GX460 and noticed that the rear window piston hardware and window hardware is rusting. Has anyone experienced this? I am still in the factory warranty period. I wonder if it should be covered. See images. I appreciate any feedback.
#37
I have similar rust like in your first photo. I just spray FF and that seems working, ie. it is not getting worse.
#39
Ahh the joys of living anywhere it snows.
This thread provides part numbers if you want to replace them
https://www.clublexus.com/forums/gx-...mountings.html
#40
Depending on the in service date of your GX a 16' could be out of 4/50 warranty so you may want to call and check with your local service department. If it's a CPO car then it will have different coverage.
#41
get a plastic brush (old tooth brush would probably work) and brush the areas, coat it with a light oil, grease or rust sealant.....
Sheeesh, don't you guys work on cars anymore?
daddiojigg (05-18-24)
#42
Okay starting now my new years resolution is to stop being sarcastic with a post or reply's.... So that was pretty much 8 or so min. ago and I am going to have to back out of that now.
Thanks for your understanding.
