Undercoating for 2019 GX 460
Old 12-02-19, 07:41 PM
ObsidianBl
ObsidianBl's Avatar
Originally Posted by MarkVII
My google-fu is weak, can you point me in the direction of a disgram?
it should be under the driver side door. Let me find the video.
edit:
Go to the 2 minute mark on this video
The following 2 users liked this post by ObsidianBl:
MarkVII (12-02-19), nuclearn8 (12-03-19)
Old 12-02-19, 07:47 PM
MarkVII
MarkVII's Avatar
Originally Posted by ObsidianBl
Your Post
Great! Thanks!!
Old 12-02-19, 08:19 PM
MarkVII
MarkVII's Avatar
Done, that was an easy job. It's got a good FF coat on it now.
Old 12-03-19, 11:01 AM
bbqsoup
bbqsoup's Avatar
How do you clean the bottom before you apply? Do you wipe down all the dirt and dust with a rag?
Old 12-03-19, 02:48 PM
MarkVII
MarkVII's Avatar
When I did the entire underside, I hit it with my power-washer, used air to blow the water away, left it sit inside over-nite, hit it with air again, then sprayed on the FF.
Just for the kdss control actuator, took the plate off, sprayed it with Meguair's all purpose cleaner, hit it with a wheel barrel brush, blew it dry, the used a can of FF to coat it.
bbqsoup (12-03-19)
Old 12-04-19, 07:55 AM
william489
william489's Avatar
I need some advice, I already have surface rust on my GX underbody, would anyone suggest to apply some rust converter first, before applying FF?
I did FF (aerosol can, not airless spray) last year for rusty area, I am not sure how much it helped, just my personal experience, it may be related to how I applied.
I found this amazon (
https://www.amazon.com/Corroseal-Water-Based-Converter-Primer-82331/dp/B001CRETZW/ref=sr_1_4?crid=3B475023LBRQG&keywords=corroseal&qid=1575474667&sprefix=corr%2Caps%2C214&sr=8-4 https://www.amazon.com/Corroseal-Water-Based-Converter-Primer-82331/dp/B001CRETZW/ref=sr_1_4?crid=3B475023LBRQG&keywords=corroseal&qid=1575474667&sprefix=corr%2Caps%2C214&sr=8-4
), it seems it has good reviews.
Thanks.
Old 12-04-19, 08:47 AM
dumbastard
dumbastard's Avatar
When I get a new GX, I'm planning to do a whole underbody coating job by myself.
I'm going to:
1. lightly sand with 400 grit paper, then
2. apply Eastwood Rust Encapsulator Platinum, let it dry,
3. lightly sand with 400 grit paper again,
4. Spray Weicon Rust Protection 2000 for black finish (This spray provided 2000+ hours of protection under salt water testing)
For inside of the frame, I'm going to spray Eastwood Internal Frame Coating
And for the rotating parts, I will spray LPS3 on a sponge and apply it to parts from there.
Of course, I will avoid spraying anything to parts that get hot.
This is the best method that I was able to come up with after hours and hours of research.
It will take me a long time, but I just want to get it done right when the truck is new.
The following 2 users liked this post by dumbastard:
jphowey (05-18-21), wnyjazz (12-06-19)
Old 12-04-19, 12:23 PM
LexMan1
LexMan1's Avatar
Back in the day, farmers would oil the underneath of their cars / trucks. I use a product called "Fluid Film" that is Lanolin based and stays on real good. It stops oxidization from continuing to occur by providing a coating. Like WD-40, but adheres much better and much longer
Old 12-04-19, 01:18 PM
ivanj
ivanj's Avatar
In Vermont one can still get that done if you look around. That's why there are so many old Volvos up there.
Old 12-04-19, 02:46 PM
LexusGXFan
LexusGXFan's Avatar
Corrosion X HD
nothing better for long term protection.
Old 12-04-19, 03:31 PM
Zivman
Zivman's Avatar
Originally Posted by LexusGXFan
Corrosion X HD
Ive researched and some say bioshield t9 is preferred... regardless, fluid film, bioshield, and corrosion X are all good
Old 12-14-19, 06:45 AM
william489
william489's Avatar
A few days back, I used a Wagner power paint plus (airless, 2200 psi per their spec) to apply FF, the tool is great, a bit heavy, but has enough power and spray nicely. For folks who don't have air compressor, this is a good option, Lowes has it on BF sales for like $50 then.
ObsidianBl (12-14-19)
Old 12-18-19, 07:23 AM
NewB2Lexus
NewB2Lexus's Avatar
Has anybody applied rubberized coating to parts of the undercarriage, wheel well maybe? Is it recommended to put something more durable to certain parts or just stick with Fluid Film and re-apply yearly?
Old 12-18-19, 07:59 AM
LexusGXFan
LexusGXFan's Avatar
I would not recommend any rubberized coatings.
Corrosion X HD or the thicker version of FF in the high wash areas.
nuclearn8 (09-07-21)
Old 12-18-19, 01:41 PM
MarkVII
MarkVII's Avatar
Yea, run away from anything rubber based.
Quick Reply: Undercoating for 2019 GX 460
