Sequential Tail lights
#31
They emailed me that FedEx cost will be much higher as quoted due to minimum volume pricing. I expressed that I was not happy as this should be very much up front information to be provided. At the end, I agreed use EMS for their published shipping rate.
#32
I agree. I worked with EMS before and they are by far the worst shipping company to work with. However, I don't agree with them that shipping with DHL is expensive. From prior experience it is about the same price as EMS if not even less.
#33
True in part. However, it is very much how you setup the account with the carrier and projected routine volume of businesses with the carrier. In any case, as long as the goods get to me with reasonable casts and timely, I am OK with it.
#36
Looks good!! Are they plug and play? I thought there was a change in the harness beginning 2017? I also don't see any reflectors on the side of the light... Probably not DOT compliant?
#37
Just a quick update, my order was shipped on 03/17 and hopefully will be showing up soon.......
#38
Chasin (07-20-20)
The following 2 users liked this post by hzhao:
Chasin (03-21-20),
craigrpete (04-13-20)
#40
After waited for a week, the tail lights showed up this morning. I gave the Seller a five star on order process, shipping and package, it was well packaged with double boxes, even with ply wood box for protection. Lights arrived without any scratches or damages.
Look at lights, the design, engineering, and building quality are pretty good. Compare to OEM lights, all details and fittings are all comparable. The new lights even added Lexus like air flow deflectors at side, but I don't think it actually serves any dynamic purpose rather for cosmetic reasons.But I have to give them the credit, it does make the lights more OEM and high end looking for sure. Installation is pretty much Plug-N-Play. It even included load resistor which does needed for OEM flasher relay on the GX. If any of you has switched the relay for auto lane change flasher as I have done, the new relay will support LED without resistors, but I leave it on anyway. The fit is pretty much spot on with a slight gap at the bottom. Two reasons may contributed to that, a) create didn't want to be in legal trouble if he used exactly the same design from Lexus; b) to using the unified design and sizing to fit both Lexus and Toyota LC. In either way, it is not a big of the deal from overall appearance.
The tail lights set also come with the bottom inserts at bumper where the OEM cable attached and with the additional guides for secure the lights in position. The new insert is somewhat a bit out of alignment as well as in slight different size. I ended up using the original ones just fine. My guess those either fits with GX in other markets, or it may used by Toyota LC Prado. Here is the photo compare the GX OEM one (left) with the new one (right):
The result and effect are very good. The "L" shape tail/parking lights are very much Lexus alike on LX and other Lexus models. The break lights which is the portion on top next to "L" are brighter and same intense with center break light. The sequential turn signal is very nice with the wrapped around effects, which is very thoughtful given it is relatively short in length. Look from behind, it definitely made the GX stand out in luxury crowd. I am just wondering why Lexus didn't do that in first place..... Anyway, here are few photos and video clips to share for everyone's reference:
Due to the angle of shot, the break lights didn't show the full intense, it actually looks very good. Overall, the lights blend into the GX style very well, more OEM looks than after market. Those are my initial opinion on them. Now will see how well it holds up over the time.
#42
thanks for posting. do you have a photo of before with the original tail lights? or anyone else with factory 2014+ clear lights. I think that gap is there.
#43
For all the fairness, I want to give all the facts and avoid any misleading or realistic expectation for anyone who wants to do the same. One more comment that I could add since we are on the subject, I wish they could do a little better job on the side of the tail lights. It is a bit boring compare to the rear.
Now I am done with all the negative points. At the end, I do like it and without any regrets.
#44
I didn’t take a photo before. Maybe someone on the forum can offer one. Now you mentioned it, I am not sure if there is a gap to begin with. I thought it wasn’t there or at least didn’t notice. It could be the result of actually color and shape of the lights. The body of the new lights is actually a bit “fat” compare to the OEM ones.
#45
NWMudHorn (04-09-20)
