2024 GX height - Wheel and tire suggestions?
I’ve been considering a GX since 2022 but for various reasons I never took the plunge. I’m fond of the new GX but I’ll have an issue: work garage height maxes out at 75”. GX luxury comes in at 75.39”. So, I need to lose a half inch.
Can anyone suggest a wheel/tire combination that you think will work well? I don’t particularly care for large wheels anyway, so I don’t mind replacing the Luxury 22” wheels.
That said, I’m a bit nervous about undersizing the tires, it’s not a particularly good look on a truck. Let me know what you think!
thanks.
thanks.
The wheel size (rim) is not necessarily the issue ... as one moves from 18" to 19" to 20" to 22" wheels, the aspect ratio of the tire (tire width to sidewall height) is typically reduced (respectively) to maintain a close to identical overall diameter of the tire between wheel sizes ... which is what determines the ride height of the vehicle. But since you have 22" wheels ... there is no reasonable opportunity to reduce the tire aspect ratio any further. So what tire size are you currently running ?
The Lexus spec has the 22 GX460 overall height at 74.2" ... which is typically running an as-delivered 265/60-18 tire that has a 30.5" overall diameter.
Use tire calculator to compare sizes ... https://tiresize.com/calculator/
To lose 0.5" in current ride height means you need to lose 1.0" in tire diameter
Originally Posted by ASE;[url=tel:11522252
11522252]The wheel size (rim) is not necessarily the issue ... as one moves from 18" to 19" to 20" to 22" wheels, the aspect ratio of the tire (tire width to sidewall height) is typically reduced (respectively) to maintain a close to identical overall diameter of the tire between wheel sizes ... which is what determines the ride height of the vehicle. But since you have 22" wheels ... there is no reasonable opportunity to reduce the tire aspect ratio any further. So what tire size are you currently running ?
Basically, I will have to pick a tire and wheel that will give me at least a 1/2” reduction in total height.
Thank you for the reply. Sorry if I wasn’t clear, but I don’t currently have a GX. I’m looking at the 2024 and the Luxury has the lowest hight at 75.39”. I need to get below 75” to fit into my parking garage at work.
I would think you need 1-inch to be safe ...
Jtycho (06-11-23)
I have a lifted FJ Cruiser ... and those low parking garages can be a nightmare ... even if getting past the "hanging tube" at the entrance ... I am always concerned that I'll get wedged while taking a turn or going over a bump on the garage floor. The FJ has an antenna that is designed to be 1-inch higher than the roof rack ... so if it "pings" going into the parking garage entrance ... it's a nice "no-go" warning.
![Rock On](https://www.clublexus.com/forums/images/smilies/rockon.gif)
A "wedgie" in High School gym class is bad enough ... but a "wedgie" with a $70,000-odd vehicle is probably worse ... or at least more expensive !
gfcipriani (06-14-23)
Originally Posted by ASE;[url=tel:11522352
11522352[/url]]Get an onboard air compressor so you can "air down" the tires ... and **** off everyone behind you in line
Sounds like you just need to find the level and parking space(s) that work ... and not continue down to the dungeon levels where the clearance always seems to be lower.
I wouldn't do this. A 1" shorter diameter tire will throw off your speedo, indicate more miles than you are actually driving, could negatively impact the handling and driving characteristics of the vehicle, and cause potential warranty issues.
Jtycho (06-12-23)
Originally Posted by omegafiler;[url=tel:11522648
11522648[/url]]I wouldn't do this. A 1" shorter diameter tire will throw off your speedo, indicate more miles than you are actually driving, could negatively impact the handling and driving characteristics of the vehicle, and cause potential warranty issues.
Yes, the speedometer and odometer and computer MPG calculation is based on tire rotations to determine distance traveled. So unless the computer is re-calibrated ... smaller diameter tires will result in ... beyond speedo accuracy ... the odometer logging more distance than actually traveled ... so warranty coverage will expire sooner than necessary.
Re: warranty issues relative to tire size ... unless you go crazy ... this is never an issue ... a 1-inch difference in tire diameter will not flag a warranty concern.
Originally Posted by ASE;[url=tel:11522694
11522694]Yes, the speedometer and odometer and computer MPG calculation is based on tire rotations to determine distance traveled. So unless the computer is re-calibrated ... smaller diameter tires will result in ... beyond speedo accuracy ... the odometer logging more distance than actually traveled ... so warranty coverage will expire sooner than necessary.
We’ll see. Maybe I’ll eventually track down a ‘22 Nori green that I originally wanted.
I did a bit of homework. The difference wouldn’t be overly significant, the odometer would read 100 miles when I hit about 97. I only drive about 5000 miles per year. Regardless, even though I’m really drawn to the GX, I may not be willing to mess with a $70k purchase.
Jtycho (06-12-23)
You'll probably need to wait for this thing to actually get on the streets, but I think you're best bet will be to just remove the roof rack, or request it to come with out a roof rack from the factory, .that'll save you an inch or two right there.
I thought of this, but I think you’ll still have the shark fin to contend with.
jer (06-13-23)
