OEM Skid Plates
Accidentally found the PDF and part numbers for OEM front and mid skid plate.
Maybe @Acrad can clean it up.
https://content.spad-ams.toyota.com/...k0Ni4zNS4wLjA.
Super Moderator
Thanks!
I will get a sticky parts thread started this weekend
Slprciv (03-28-24)
Front Skid Plate PT938-60240
Front Skid Hardware Kit PT938-60240-HK
Front Skid Bracket PT938-60243
Mid Skid Plate PT938-60241
I'm a bit confused - I thought this would be an identical replacement for the original equipment skid plate that comes stock on the GX. But this isn't identical - note the additional bracket that needs to be installed. Also, it seems like it is embossed with "Lexus" across the front of it (mine certainly isn't), and also appears to be missing the oil filter and oil drain access doors. It this some kind of "upgraded" skid plate to what came from the factory?
PT part numbers are always an accessory. My guess is upgraded
Siblue (04-29-24)
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
