•• 2024 GX 550 Discussion
#136
More informed speculation
https://www.youtube.com/watch?v=WZffYtMQUMk
Piney1 (06-21-21)
#138
If true I’m out. No V8 means no new customer here and a new LX was being considered for a few years down the road. I’ll buy used and keep it on the road until I die. Big mistake Toyota. Ugh I hate I4 & V6 turbo engines in vehicles that needs a damn V8. If I want a turbo for higher altitude driving I’ll add one on a V8.
#140
Originally Posted by TheHighLow;[url=tel:11050000
11050000]agreed, it may not be fast but the current V8 is more than adequate for DD and offroad. It's silky smooth and the engine sound fits the boxy profile of the GX.
a 2.7L GTDI will run circles around the current V8 in all of those categories. The only thing left to complain about is the sound
#141
I also prefer the 5.0 in the F150, the sounds and feel of the engine in the cabin just fits the truck better.
a 2.7L is gonna sound like a weedwhacker sorry, no thanks. it's ok in an X5 or a RX350. Heck the 4.0L in the 4Runner sounds better than the 3.5 in the Tacoma
#142
Originally Posted by TheHighLow;[url=tel:11050104
11050104]i prefer the sound and feel of a V8, especially in a heavy *** vehicle like the GX460. Nothing like hearing that V8 come alive when you mash the throttle. It enhances my driving experiences. I didn't buy this for good MPG's. And I love the fact that this engine is pretty much bulletproof.
your either gunna get a turbo motor or some V8 with a crappy displacement on demand system.
why do you think they put that dog crap 3.5 in the Tacoma? Its their best selling truck so they were aiming for mpg. It certainly wasn’t for driving enjoyment.
and hell, the V8 in the GX kinda sucks when it comes to throttle tuning and transmission tuning. Thats why I got the pedal commander and its still not great. Are they just that bad at tuning or are they trying to get the thing to squeak out another 10th on an mpg?
#143
After towing my travel trailer 2.5 hours through Wyoming yesterday, it reaffirmed that I would gladly welcome a GTDI making similar power numbers or even a little less than the 4.6L. The 4.6L was pretty much at its limits in terms of power and I was having to rev it pretty good just to maintain speed on flat roads because I was fighting a headwind. Was pretty much hopping back and forth between 3 and 4000 rpm the whole way and a few times had to jump up to 5k.
Even just heading out to pick up the trailer it was hunting a lot and having to climb in 4th gear.
A nice GTDI that can make 330 torque at lower RPM and still produce it at the elevations i was at would make it a lot more enjoyable.
#144
#145
Need is a strong word.
I prefer function over form. Listening to the V8 drone away at 4000 rpm for 20 minutes straight kinda takes away from the "driving experience".
Ill buy a Mustang 5.0 or SRT Durango if I was really looking for an exhilarating experience.
#146
I like the non turbo, non direct injected tried and true V8 that the GX has.
Sounds like you need a turbo charger pickup for your towing needs...
With all the gear hunting, I would love to have seen your ATF temperatures for your trip.....
#147
I installed a trans cooler on the GX. Temps never got above 205F on this trip. My past trip, before the cooler, I saw 245F so I got home and changed the fluid out and added the cooler right away. But Toyota seems to like to put lackluster transmission cooling in the new trucks so it must not be a huge deal for them. 245F is what the Tundra hit in the recent TFLTruck IKE test.
The GX actually tows the trailer surprisingly well other than the lack of power. Stability and handling wise it's pretty good. You feel things a little more than my truck but my truck is 6200 lbs empty and has a 157" wheelbase so that is to be expected. I had no issues with the GX in crosswinds or on some of the twisty mountain roads and no problem doing 70mph on I-80. Power is the one area it lacks.
At the end of the day, the next engine won't be a non-turbo and/or non-direct injected. It simply won't. The best you can hope for is a DI V8 with cylinder deactivation, but all signs point to the next truck motor being a TT V6 with direct injection. Toyota doesn't care what you think, they are going to develop engines that make sure they are not paying fines out the Wazoo to the EPA. Look what happened with the Tacoma motor. Difference between the Tacoma and the Tundra/LC/Possibly GX is the TT V6 will actually have some decent low end power.
#148
Does any manufacturer currently make a cylinder deactivation engine that works well? I've only heard bad reports of reliability and complications from that technology. I would imagine that toyota engineers would make a decent version, however like everything, an increase in complexity leads to an increase chance of failure.
#149
Ram's system sucked because they had a bad batch of cams is my understanding.
But since Toyota uses DOHC motors, I don't know how it works. I know the 2021 F150 5.0 now has cylinder deactivation and is DOHC. I am not positive how they do it but it is V4 or V8 only.
But at the end of the day, you are right, the complexity increases. This is why I don't see a GTDI as a bad thing. Is a TT V6 really worse than a V8 with DoD and other fancy wizardry to make it more efficient? Turbos are not complex. They are not expensive. And they are not hard to replace if one did fail. They hang off the side of the motor and have like 6 bolts at most holding them in. Almost everything DoD related is inside of the motor and is much more complex to fix.
#150
There is still the Nissan Armada. That will get you a LC size engine/truck but at GX price.
