•• 2024 GX 550 Discussion
#511
Hope it would be that easy, similar to a GX470. However, if they have a different loading height to match and level the third row like the GX460, may not be possible. Keeping fingers crossed!
TexasFunRunner (06-14-23)
#513
Calling any mechanical engineers, given that the GX460 has an 8.1 ground clearance, 109.8 inch wheelbase and 21d breakover, do these numbers imply that the new GX550 will have around a 9.4 inch ground clearance and maybe closer to 10 inch for the Overtrail?
![](https://lexus-cms-media.s3.us-east-2.amazonaws.com/wp-content/uploads/2023/06/Screen-Shot-2023-06-08-at-4.26.19-PM-1024x580.png)
#514
Interesting that for all the offroad talk for the new GX, the approach and departure angles are still worse than the 2010-2013 GX460 models (Approach: 28 vs 26, departure 25 vs (23/22/21)).
TexasFunRunner (06-15-23)
#515
This new truck is on 32.6" tires so probably sits more like a 15" radius, but the ring gear is now a 9.5", so 4.75" radius. My guess is the ground clearance spec is just about the same, maybe slightly better.
Not that I plan on switching from my current GX anytime soon, but I would like to see what the new LC looks like. If that gets better gas milage, and given that this GX doesn't look particularly plush/lux, than maybe I upgrade into the LC when it is time. I can (but just barely) deal with the terrible efficiency of the current gen to get the smooth/bullet proof 1UR-FE. But if I have to move to a more complex/less smooth/linear turbo 6 or 4, I would rather trade off any extra power above what the current GX has (301HP/329 trq) for better fuel efficiency - something in the mid 20's would be nice. A hybrid in the 30's even better.
And as far as efficiency, this is essentially a half ton truck. The weight is the same as a tundra, the rear axle is the same size as a tundras, and the whole driveline is the same size, and it is only Full-time 4wd where as most half ton trucks can run in 2wd. The ONLY advantage this new GX550 for gas mileage is how big of a hole its punching through the air, but its close.
given the weight of these things nothing will get into the 30 mpg range but I am curious as to the GX 550 Hybrid. That should flirt with 20mpg + but again it will be heavy….agree re getting better efficiency that’s why they should have retained the v8, given it DI, hybrid assist and the 10 spd auto. Could have kept the smoothness, reliability and improve efficiency (somewhat).
A V8 would have required far more than just DI and a 10 speed to be efficient. Look at the Nissan Titan. 5.6L DI V8 with a 9 speed and the MPG's are horrible compared to any other half ton. Their MPG's are 14's to low 15's while virtually every other half ton is in the mid-16's or higher. They would have needed displacement on demend and all sorts of other stuff to make it competitive and then your reliability would have been out the window.
A hybrid V8 also wouldnt be a great option. The main reason V8's are inefficient is because they are too large for normal daily driving loads and they see a tremendous amount of pumping losses due to manifold vacuum. The large displacement of the engine is causing it to fight itself. Making it a hybrid would make the V8 fight itself even more by reducing the load even more unless they implemented displacement on demand too. GM tried a hybrid V8 silverado and Tahoe and it sucked.
Where did you get these numbers? The EPA lists a 2wd tundra hybrid at 20/24/22 and the 4wd non-hybrid is 17/22/19. And thats a truck that does not have full-time 4wd.
#517
Would anyone pay 72k for a 6-7 year old truck with 72k miles when you could get essentially the new version of the same truck for $75k with 0 miles. Lets face it, this new GX550 is just a 300 series including eKDSS and a rear locker.
jphcbpa (06-15-23)
#518
Thats a big question mark for me too. But imagine if it did come in a $75k what would happen to the Land Cruiser 200 series prices lol. I went and looked at a 2019 with 72k miles the other day and the guy wanted $72000.
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/1658x1236/lc200_ebebf492ced8b50759177ce23b6843f2f0757539.jpg)
Land Cruiser 200 US Sales source: https://carfigures.com/us-market-bra...a/land-cruiser
#520
Super Moderator
#521
#522
Direct from the Toyota.ca website https://www.toyota.ca/toyota/en/vehi...specifications
GX550 has no Split gate. No V8. Also LC200 is way, way, way more of a flex for certain folks than a GX ever will be (and I have a GX - so I am not one of those people). So I am not sure how much it will affect prices of the LC200 given how few of them are on the road.
The beautiful thing about this GX550 is that it will hopefully mainsteam the land cruiser platform a little more. The 200 series should never have been sold solely as a luxury SUV. Its not particularly good at it, hence why GM sells 12 times as many escalades per year at the same price. A budget cruiser that came in cheaper than a Sequoia would probably have sold really well.
#523
#524
The problem is the GX is getting the 2.4L hybrid out of the Tacoma. Its not going to be the 3.4L hybrid from the Tundra/Sequoia so there is more variables than just the hybrid motor.
#525
I'd be delighted to get an Overtrail+ for 75... If I order two, do you think it will be possible to get them for msrp? I'm not familiar with how Lexus usually deals with markups.
