How to program 2006 GX 470 remote
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
System Operation:
Pressing LOCK button activates alarm and central locking.
Pressing UNLOCK button one deactivates alarm and unlocks driver's door only.
Pressing UNLOCK button twice within 3 seconds deactivates alarm and unlocks all doors.
If vehicle is unlocked and doors or trunk/tailgate not opened within 30 seconds, locks/alarm are reactivated.
Programming
When:
* Key remote transmitter added or replaced.
* System malfunction
How:
* Driver's door open, all other doors closed, key removed from ignition switch.
* Within 5 seconds:
* Insert and remove the key from the ignition switch twice.
* Within 40 seconds:
* Close and open the driver's door twice.
* Insert and remove the key from the ignition switch.
* Insert the key into the ignition switch and close the driver's door.
* Switch ignition ON and OFF once to program a key remote transmitter code whilst retaing the original codes or twice to program a remote transmitter code whilst erasing the original codes. Three times to check how many key remote transmitters are currently registered or five times to erase all registered codes.
* Remove key from ignition ****ch:
* System should now lock and unlock vehichle. Once, twice or five times depending which mode has been selected. One to four times, slowly, to indicate number of key remote transmitters registered.
* Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds.
* Within 3 seconds:
* Press and release LOCK or UNLOCK button.
* System should now lock and unlock vehicle once to confrim registration, twice to indicate registration has failed.
* Repeat button procedure to program remaining key remote transmitters.
NOTE: To exit programming mode: Open driver's door or insert ignition key.
NOTE: A maximum of 4 key remote transmitters can be programmed.
Programming
When:
How:
* Within 5 seconds:
* Within 3 seconds:
Thanks for the steps. WOW...a lot of steps.
Lexus of Westminster will program the key for $55...well worth the money b/c it will take me 30 mins to study then do the steps above properly. $55 includes a car wash.
Ryan
Ryan
Sorry guys, i am new to this forum, I searched many many pages on this form and I still can't find this information.
I just purchased a 2007 GX470 and it only came with one master key. I purchased a master key on eBay and was hoping to find the instructions to program the remote.
Can someone please post the instructions or a link that has it.
Thank you so so much!
Also , where can I get the key cut in the NYC area at a reasonable price?
System Operation:
Programming
When:
How:
* Within 5 seconds:
* Within 3 seconds:
Programming
When:
How:
* Within 5 seconds:
* Within 3 seconds:
I tried 2 different brands of aftermarket remotes on my wife's 2005 GX. Couldnt get either to program. I bought remotes from Lexus and had no problem programming the remote or adding the transponder code to the ecu. Techstream is the easiest way to add remotes, and will tell you how many you have and allow you to erase old ones.
You need a programmer to make it work. A guy on ebay cuts keys from your photo of it cheap- I got a lock out key from him and works 100%
https://www.ebay.com/itm/BLADE-CUT-I...S/152586017502
hope that helps
hope that helps
I have a 2007 GX470. But only one remote. I bought a OEM Lexus remote 89070-60801 off ebay. I took it to a locksmith to cut it and program it. The programmed the chip to be able to start the car and manually work the locks. But the could not program the FOB remote lock/unlock functions.
I tried the instructions found elsewhere in the forum for DIY programming FOB involving, inserting the key, opening and closing the door, etc. Also, no success despite many tried at this. In the end I get two locks/unlock telling me it was unsuccessful.
Any other suggestions for getting the FOB remote lock/unlock buttons working?
New message to: 1010keys
Driver’s door open, all other doors closed, key removed from ignition switch.Within 5 seconds:
Within 40 seconds:
Close and open driver’s door twice.
Within 40 seconds:
Insert the key into the ignition switch and close the driver’s door.
Switch ignition ON and OFF:
*Once to program a key remote transmitter code whilst retaining the original codes.
*Twice to program a key remote transmitter code whilst erasing the original codes.
*Three times to check how many key remote transmitters are currently registered.
*Five times to erase all registered codes.
Remove key from ignition switch.
System should now lock and unlock vehicle once, twice or five times depending which mode has been selected. One to four
times, slowly, to indicate number of remote transmitters registered.
Within 40 seconds:
Press and hold LOCK and UNLOCK buttons Fig. 1 or Fig. 2 simultaneously for 1.5 seconds.
Within 3 seconds:
Press and release LOCK or UNLOCK button Fig. 1 or Fig. 2 .
System should now lock and unlock vehicle. Once to confirm registration or twice to indicate registration has failed.
Within 40 seconds:
NOTE: To exit programming mode: Open driver’s door or insert ignition key.
hi.
Within 40 seconds:
Within 40 seconds:
Within 40 seconds:
Within 3 seconds:
Within 40 seconds:
Thanks.
Yes. These are the instructions I have tried myself. Each time at the end, I get the two cycles indicating it did not pair.
I have tried at least 6 times, using different pace of steps, hoping maybe a few seconds might made a difference.
I'm thinking I got a dead OEM remote.
Thanks.
Any help or thoughts are greatly appreciated.
HaywardLex
GX - 1st Gen (2003-2009)
10-09-16 07:01 AM
2006, 470, control, garage, gs, gx, gx470, instructions, key, lexus, program, programming, remote, transmitter, video
