Bluetooth Audio
Has anybody tried using the bluetooth audio function with an iPhone?
I have found that it sounds great, but it often cuts in and out. Has anybody else experienced this and/or found a fix for this?
Thanks.
Thanks.
I've paired my iPOD Touch with the HS250h Bluetooth audio and experience exactly the same problem. Sometimes it works fine and sometimes it cuts in and out. The easiest way to play your tunes (for longer drives) is cabling to the USB port and take advantage of the charging function as well.
Also I notice when I answer the phone, I have to wait a second or two before I start talking or the other person won't hear the first part of what I say (short delay, but enough to notice and be annoying).
Update: sorry, I didn't read close enough and thought you were talking about the phone bluetooth connection. I use the audio mostly without problems. Occasionally it will freak out and do some weird things, usually turning the phone off and on a few times will clear it up. I have an iPhone 3GS.
I pair my iphone everyday and listen to an app that streams the radio broadcast from Denver. I dont usually have a problem unless I come across a deadspot where I will loose cell phone reception.
