Another 1000 mile tank!
Just filled up, the HS250h allowed me to get the 2nd 1000 mile tank in a row. The potential is definitely there. Here are the key figures:
1065.3 miles
16.669 gallons
67.1 mpg per MFD
63.9 mpg actual
The temperatures are starting to fall here (we're seeing in the 40 degree range on some mornings) so I think it's going to be a lot tougher to maintain decent mileage until spring arrives. I will not give up though.
1065.3 miles
16.669 gallons
67.1 mpg per MFD
63.9 mpg actual
How did you get 16.669 gallons into a car which has a 14.5 gallon gas tank?
I'm looking for any trick to maximize the range on a tank of gas and your skill in getting an extra two gallons into a 14.5 gallon tank would certainly help my numbers.
Embleer Frith! That's nice mileage.
My total commute is 40 miles roundtrip. I use a route that has the fewest stops possible and very few left turns. Posted speed limits are between 25-50mph on various streets. My maximum speed is normally in the upper 40's. I do a lot of pulse and gliding. With stops and everything included, my average speed is in the low 20's. I do leave very early (before 5am) so I don't really see much traffic. I would have to say overall it's a pretty favorable commute for mpg purposes. It's also pretty flat, some rolling hills, one major one.
DWB
DWL
Face out/Potential Parking
P&G
Warm-up P&G
RR
Route planning
Light timing
NICE-on coasting
NICE-off coasting
Max sidewall tire pressure plus
Grille blocking
Reverse passing
On my second last fill, I added 16.688 gallons. Needless to say, I was shocked. On this last fill, I added 16.669 gallons. The tank is definitely not 14.5 gallons. It took a lot of courage, but now I know how large my tank is.
My average speed is in the low 20mph range. I use several hypermile techniques, as follows:
DWB
DWL
P&G
Warm-up P&G
RR
Route planning
Light timing
NICE-on coasting
NICE-off coasting
Grille blocking
Reverse passing
DWB
DWL
P&G
Warm-up P&G
RR
Route planning
Light timing
NICE-on coasting
NICE-off coasting
Grille blocking
Reverse passing
Not to mention the safety factor. Drafting is not in my repertoire.
