Tire Pressure on the dash question
The tire pressure indicator on the dash (multi-information display)-
( example) 33-32-31-34. My question is: What order is this in: is the 33 the left front- 32 the right front- 31 left rear-34 the right rear? Also in the owner manual - Page 439 - Tire pressure RESET PROCEEDING has anyone done this on HS250? I never saw a reset but I will be looking now.
Thanks in advance . James
Tire Pressure Answered
Here is what I found : I have the 18" tires.
32 32 33 33
RR LR RF LF
RR= Right Rear
LR= Left Rear
RF= Right Front
FR= Left Front
Also there is a reset button under the dash but I think it just for the flat tire indicator. The 32 and 33 is the manual recommended PSI.
32 32 33 33
RR LR RF LF
RR= Right Rear
LR= Left Rear
RF= Right Front
FR= Left Front
Obviously I never bothered to refer the manual
My understanding is a little bit different on how this works.
The "sequencing" of the tire pressure has to do with the order in which the tps sensors register themselves. I thought I read somewhere that there wasn't a guarantee that the sequencing would always be the same.
Well, that (i.e. manual reference) definitely settles it then.
Man, I should start reading these manuals. All this time I assumed the order was FL-FR-RL-RR...and i've been assuming the same thing the past 5 yrs for my Nissan quest as well.
In other words, if my display shows 34 34 30 34, should I know the Front Left tire needs air, or do I have to check each tire to determine which one is low (if it's not visually obvious)?
Am I to understand this to mean the order displayed will always be the same, i.e. RL RR FL FR, or does mean there is no order at all?
