HS 250h Model (2010-2012)
Rear View Mirror
Old 05-15-14, 05:05 AM
srumman
srumman's Avatar
Default Rear View Mirror
HI Guys,
( HS250h 2010) The left rear side mirror tilt at reverse, and when I change to drive mode it return back, but the problem sometimes it is not return to previous mode and go to the up, so after revers i have to return the mirror back manually.
The right mirror good, but the problem with the left side mirror only.
Can anyone advice please
Thanks
Samer
Old 05-17-14, 12:38 PM
TheAirman
TheAirman's Avatar
If it works manually, I would guess it's in the reverse switch or the computer itself.
You might want the dealer to look at it with his computer.
Old 05-17-14, 08:56 PM
srumman
srumman's Avatar
Thank You , i will check with the dealer.
Thanks
Samer
IS350atWOT
ES - 6th Gen (2013-2018)
07-08-13 06:23 PM
JoeKuhn
12-29-12 03:09 PM
PFB
08-31-10 08:27 PM
JDKane527
07-16-10 11:18 PM
Homchenko
SC- 1st Gen (1992-2000)
09-23-06 04:33 PM
Quick Reply: Rear View Mirror
