In cabin air filter replacement
I looked. Nothing in the repair manual about the filter. But like ceads9 said.......super easy.
Just pull up on that little shelf in there where it says "removable" Its just press fit in there.
Next open the little latch on the left side of the glove box and remove the little door.
Then open the little latch on the right side of the white filter door and pay attention to the the "up" wording. The filter door has a latch on one side and a slot on the other so it come out at an angle. Keep in mind the air flow direction is "up" when replacing the filter.
Finding the Cabin Air Filter Location RXZ 350 2015
I decided to go the AutoZone. The people there are usually helpful. He showed me where to locate the cabin filter. Back of the glove box is a black cover. You have to push it to the left and then it should pop out easily. Then you see the filter clips and remove it. I paid $15 for a new filter and the dealer wanted $40 plus labor during my service. The manual does not have instructions on how to change these for obvious reasons.
Cut-Throat
04-07-13 09:59 PM
