Rear LED tail lights (LED) burnt?
OK, a little more. A quick check of the parts manual, shows the numbers:
81591-75030 (LH)
81581-75030 (RH)
Both of them were about $200 online. I just looked at the first ones that popped up on Google. Pretty expensive for 50 cents worth of LED's, I'd say.
Here's the "how-to" from the repair manual:
Rear Light Assembly.pdf
81591-75030 (LH)
81581-75030 (RH)
Yeah, I still plan to pull one off and check it out at some point. Just haven't had the time to bother with it. Like you said, there's not even a brake light, so it's almost more decoration than purposeful. The dealer told me it would still pass inspection. So this is pretty far down my list of projects, including watching football :-)
That's what I'm thinking.
I didn't want to pull mine off since it's not broke yet.
I might have to do with how hard we each close our trunk lids. Some people let them drop. Some people close them easy.
Quick question, does the 2nd Gen HS250h tail light fit in the first Gen's? I was looking at pictures and it almost seems like that's all they have changed: front bumper spindle grille and rear tube lights.
Those tubes lights in the second gen makes the car look so much more sophisticated. Maybe you can get a set from Japanese?
Like these? They look like the same shape. But good luck finding a set, and I hope your pockets are deep.
Attachment 371623
Attachment 371623
But my pockets are shallow
Just replaced the rear LED tail light assembly on my 2010 HS250h. $230. 2 burnt out LEDs; one burnt out LED in each of two groups of 3 LEDs in series. Here's what they look like.
2010 HS250h rear LED tail light assembly with lens removed
2010 HS250h rear LED tail light assembly front
2010 HS250h rear LED tail light assembly back
Great pictures. Thanks for sharing !!
Did you try to fix them?
Looks to me, by the pictures, that it might be one resistor per each three LED banks. So it might not be the resistor. And from the looks of how those LED's are mounted, it might be just broken connection on those two LED's.
That's my guess from just looking.
Did you have to break the tail light assemble apart to get to them, or can they be put back together? From the first picture, it looks like the two parts were glued together.
i have the same issue,
im working on my lights and will update the group with the steps once i done.
TheAirman (03-30-18)
Finally I’ve done it myself.
this is after fixing as original.
after adding more LEDs
Separate the assembly by heated air ( it takes about 40 mints), and checked the wiring and there was a disconnected wires. Just soldering the pole again and that’s it.
It seems if 1 LED Bulb is missing, the whole row wilt run off, the soldering can be broke due to opening and closing the trunk.Anyway I have added extra bulbs to the whole assembly and it looks much more better.
Aqualung35 (06-03-24)
