Which Fuse protects the USB Port?
Hello Everyone! I need some help!
Does anyone know which fuse protects the USB port mounted on the right side of the console? I have a 2010 HS250h. I wasn't paying attention and tried to plug the wrong end of my iPod cable into the USB port and shorted it out (I think...all I know is the radio does not recognize my iPod). I checked the owner's manual and could not find a specific reference to a fuse for the USB port.
I sure hope someone can help!
STJr
Prescott, AZ
STJr
Prescott, AZ
You can start pulling fuses and identify the one that has the broken wire. The fuse boxes are usually in 2 places. One is inside the car near the drivers left foot somewhere. Then under the hood should be a box. Both of these usually have a key printed inside their covers that identifies the fuses. Check the owners manual for more help finding them.
Thanks for responding! I was hoping to avoid pulling and checking each fuse. The fuse box under the hood is easily accessible. But the fuse box under the dash is fairly easy to access; but getting the fuses out is a nightmare! The fuses are really small and tightly packed together. The keys inside the covers of each of the fuse boxes are pretty generic and none of them contain a reference to USB. The owner's manual is more descriptive; but again, no mention of USB.
Well you can narrow it down and begin by checking the lowest rated fuses first as I bet it is a 10 or 15 amp fuse.
dustin2413
HS 250h Model (2010-2012)
02-07-15 01:32 PM
lenunn1923
08-21-08 06:33 PM
