LED DRL Mod *need inputs*
just wanted to see what options are out there... i have a 2010 base w/ navi, came with the stock halogen lights, i had since added an aftermarket HID on the low beams, but i feel that the factory highbeam DRL is dated... Considering how most cars out on the road come with some type of LED or LED Strip (lexus, acura, audi), i wanted to give the car an updated look..
so my plan:
Disable the OEM Highbeam DRL
Rewire the turn signal to run as DRL w/ LED bulb (wired to ignition, which will eliminate the front parking lights)
Rewire the factory parking light as the Turn signals..
in hopes of doing so, with a bright enough LED for the new Turn Signal, i hope to have the look like the new Lexus w/ the LED Strip DRL
so my plan:
Derek904 (03-07-22)
Derek904 - I doubt you will get a response from s2kvee's 5-year-old post as he has only made 9 posts and the last one was in 2018! He may not even have the HS anymore.
