Bluetooth audio HS250h without navigation display
Hi Guys,
I'm interested in buying a HS250h. I have recently discovered that it does not have the navigation option. What I want to be able to do is stream audio thru my iphone to the speakers of this car thru bluetoth.
Navigation display is important because that is where you go to configure and select bluetooth when running your audio thru it.
The hs that I'm looking to buy does not have this option available. the navigation display. It does have bluetooth.
What my question is; would I still be able to run my audito from my iPhone thru it? Or is it only for phone calls?
Urgent responses are appreciated,
Thanks.
Thanks.
I don't know but suggest you look and search in more active forums such as the one for the ES350 https://www.clublexus.com/forums/es-...2007-2012-180/
or RX350 https://www.clublexus.com/forums/rx-...2010-2015-212/
These may partly answer your question https://www.clublexus.com/forums/es-...bluetooth.html
HERE IS A LINK TO THE OWNERS MANUAL ONLINE https://drivers.lexus.com/lexusdrive...anuals?type=om
KGK
NX - 1st Gen (2015-2021)
09-30-16 05:09 PM
