RH 450h 2010 ENGINE OVERHEAT
MrHoangChu (06-18-24)
Please write more details. Like what maintenance?
First suspect for cooling issues is coolant [is it full, is there air trapped]. If the coolant was drained during maintenance, did you put the vehicle in service mode to fill up and purge air].
Next is air flow? Is the radiator air flow good?
Is the thermostat working correctly?
Does the radiator fan run after the operating temperature is reached?
Salim
PS: Please search on "coolant"
Salim
LexFather
11-02-10 04:58 AM
