2010 lexus RX hybrid battery failure
Hi,
so my hybrid battery has apparently failed- or that’s what the repair shop I took it to is telling me-. Is it possible to only fix specific cells on the battery or will the entire battery need to be replaced? If only the cells how would the shop figure that out? Thank you
I would suggest take it it to a hybrid/ev shop. They should give you all available options to you.
If you have the equipment you can find out the bad cell via communication tool or you can do cell by cell check with a meter.
Be careful as the voltage level is lethal. There are plenty of information in the net with videos.
Salim
Salim
Margate330 (07-08-23)
There is even a national chain of franchised hybrid shops plus a lot of local independent ones.
https://www.thehybridshop.com/locations
Yes. Professionally rebuilding the battery is the best option. For example, when my HV battery failed in my Prius, I had it rebuild by replacing 4 modules and balancing it for about $550. 3.5 years later still runs strong.
Hi 360LexusES,
Just out of curiousity how many miles did you have on your RX450h when the traction battery failed? And what signs did the vehicle start exhibiting before the traction battery failed?
about 140k miles, I wound up going with a used hybrid batter out of a 2015 RX. Might not have been the best decision cost wise but seemed like I couldn’t get anyone to just fix the hybrid battery on Long Island
driguard
06-22-18 07:25 AM
