Warning light on Lexus 450h
3rd Gear
Hello all, this is my first time having lexus, RX 450h F Sport. I bought it after 2 times general check up and both said all are good, but in couple days after that, the light came to me and haunting me all days (engine check, PCS, slip warning, brake light). Tomorrow i will check again with different mechanic, and i hope my boy is in a good shape. Any opinion from senior here? Thank in advance.
Amber engine check light PCS warning light Slip warning light Regenerative brake warning light
Do not think the worst at this time.
Mechanic should have a tool to test and report a one or more "error code(s)" stored in the RX computer. If you are interested, you can purchase that tool "OBDll" reader. They are inexpensive for the basic tools.
Once you get the error codes, list them here and we can go from there.
Generally, I recommend that write those codes and clear them [ask the mechanic to do so] and when they appear again take action if they are the same codes.
A bit late, but before purchase the check should include reading the codes and if the computer says something is "not ready" wait few days to read the code. There is chance that something new has happened, but more likely the previous owner cleared the codes and you are discovering those now.
Salim
Salim
3rd Gear
Salim
Salim
3rd Gear
The problem is P0A80..
confirmed by 2 mechanic, that the battery should be replaced. Case closed.
Yeah the result is the worst case scenario, the battery isnt in good shape.
Again the diagnosis needs to drill down to actual failure.
For EVs and hybrids there is an option to remove-replace cell(s). This can reduce the repair bill substantially.
Salim
Salim
relm1
RX - 4th Gen (2016-2022)
01-16-17 08:29 AM
