350h downshifts (almost 4k RPM) when taking foot off Accelerator
#46
Seems like totally normal behavior and nothing to worry about. Happens to my car too, not often and not predictable but also does not seem to be a problem. Surprised the techs are not better informed at the dealerships. I would guess that the control systems gurus at the dealerships know how this works and are not asked all the time by the mechanical techs when a customer "complaint" is registered with the service writer. I was never concerned but probably would have never found this excerpt from the manual. Thanks.
WellsB (12-20-23)
#47
The days where you run into an experienced Lexus tech are far and few between. Lexus dealerships, like everyone else, is struggling to find people to fulfill their service needs. Turnover is high and pay is low. Asking them questions I a crap shoot!
#48
I have not noticed it going much over, say going down the Vantage hill on I-90 in Washington State. It is about a 7% grade, I believe. Posted speed limit is 70. I don't think I have ever noticed that the car uses engine compression to slow down, unless there is cars in the adaptive cruise screen.
#49
Where I live, the roads are as very flat
I can be going 25 MPH on a smooth level surface with no one around and it will do it. It’s very scary when the engine continues to rev extremely high when you were coasting down to 5 mph. Love my car, but not the issue that I am experiencing. 😔
CCGS (12-21-23)
#50
Predictive SOC control
It's not overcharging. It is preventing overcharging, and also preventing excess discharge. It's a relatively small battery in a relatively heavy vehicle. That means it will both discharge and charge fairly quickly. I imagine that driving style would play a part in it as well. Of course, something might actually be wrong with some vehicles, but unless we know what the vehicle is supposed to do under different conditions, it's a guess as to whether it's normal or not. I do wish there was a guide on what to expect in the manual.
I did find mention, in the manual, of predictive functions that could be causing perceived issues.
#51
It uses the Lexus navigation system to work this function? I've never subscribed to the Lexus navigation system. This could be why I've never experienced this phenomenon. Or, because there simply aren't any long downhills in my part of Texas?
Being used to a lifetime of manual transmission use, I frequently downshift (I know, it's an ECVT) the pretend gears to brake and charge. I never drop down more than 2 gears because a 3 gear drop just sounds too severe and stressful on the power train.
#52
One big difference, is the Venza does not have a tachometer. Sorry folks. My bad. In the Cruise control , it does not use engine breaking. It actually uses the breaking system to slow down. Low speed, high speed, it doesn't matter. I couldn't get the car to use the engine for compression braking, unless I physically down shifted. I did not try down shifting at highway speed.
#53
Thanks for the information from the manual. I have experienced all of the above but my navigation system has not been engaged.
I guess it comes down to two things. Slope and current battery level when the high rev behavior starts.
CCGS (12-27-23)
#54
Engine Downshift Noise
Hi All, I have the 2024 Lexus RX350h. At times which is very often, the car feels like it is gone into the second gear and makes a loud downshift noise. I'm not sure why does that happen. I also have the ES350 2023 and that is so much more refined and no problems + smooth power when needed.
How can lexus make such a car which sounds so backwards.
If they would have the 6 cyl engine, then the car would be perfect.
WellsB (06-24-24)
#56
Engine RPM
I purchased a brand new RX350h 2023.
1. There was no problem for about a month or two after I picked up the car, but after that, the RPM suddenly increased, and a loud noise occurred. The engine RPM increases excessively acceleration. This is a phenomenon commonly observed in cheaper cars or very old vehicles. When I press the accelerator, the RPM easily exceeds 3000, and the engine produces a strained sound. This is quite different from the Audi I currently own. It is similar to the 10-year-old Hyundai SantaFe that I once had. However, after the scheduled visit and diagnosis, the tech manager said it's normal. How is this normal? But I am continuing to drive it because I don't have any choice. I still don't believe it's normal based on my last 40 years of driving experience with many different brands of cars. It's common sense. To notice this, no special skill or knowledge is needed. How about yours ?
Sure, here's the translation:
2. I was shocked when the foreman I was testing with said that Lexus is not a luxury line but just an entry line. Is it true that the Lexus brand is just the border between an ordinary car and a luxury line?
#57
Is this the first E-CVT hybrid you’ve ever owned?
WellsB (07-03-24)
joelkrh
Hybrid Technology
08-02-08 02:59 PM
