12V battery inquiry (new) from old Thread
(2006 RX400h)
I don't know if I know where the traction icon & battery icon are or how to view it - Could someone post a photo?
I always have my center display set to this one (see photo)
Also, the bottom & side button/**** lights of the stereo are off (also see photo). The dealership (Toyota) says they'd have to pull the dash to fix it, and basically refuse, saying I would have togoto a Body Shop to have this done. Are they just not wanting to do it for me? Could it just be a fuse?
The dealership also says there is NO WAY to check if the hybrid battery is beginning to die. Says that the only telltale is the Check Engine light comes on. Also,,, are they just lazy? Or is that correct?
No, it's only yellow for the traction icon that doesn't always come on. and the battery icon is in the center box of the dashboard when touching the display button on the
wheel. It's always a black background with white lights that shows you how the car is cycling in real time. That display is separate from all warning lights.
(2006 RX400h)
Hopefully, a knowledgeable tech can give you better direction. Don't give up. They are good vehicles imo. Just hard to diagnose for a regular driver like myself. I've learned so much about my car from a few techs and others' experiences!
I'll attach an older picture of mine that I'm describing.
This is what I watch after changing a battery to watch it cycle from engine/wheel/hybrid. If you have the same year you can select 'display' button on your steering wheel 2006RX400h
Last edited by pakris; 11-13-23 at 03:00 PM. Reason: Add picture from my other post
Thank you, I figured it out,,
I never push the center button on the right side of the steering wheel so I didn't know that the screen under the odometer / speedometer could change over to those icons.
Is this icon showing the Hybrid battery status, or the Regular 12v battery? I thought it was for the Hybrid.
Mine is a 2006, I've had it since 2021, and I'm the second owner also - Mine lived in Beverly Hills CA driven by an elderly lady. (I'm in Oregon.) Miles are now at 126k
_
_
What year is your car? That doesn't look like my dashboard view behind the wheel. Mine is 2006 rx 400h. I'm not a mechanic by any means and had a bad experience years ago that led me to this forum. I'm the second owner/driver of my car since 2016 and most issues were with the 12v battery going bad. I replaced the last one with a better battery (Optima yellow top) and it lasted more than 3 years.
pakris (11-14-23)
(2006 RX400h)
PS: You have a good MPG for such old battery/car.
2. They lied to you - the dash shouldn't be removed. You don't have lights in radio UNIT, and it's easy to remove it (https://www.clublexus.com/forums/rx-...ml#post9689729). Probably, you need just to replace bulb(s) inside the unit. I would recommend to find the service who do electric works and get consultation. Don't ask dealers - high labor costs.
How to remove:
3. They CAN, but they are extremely lazy to do this and will read the errors only. iMSQ posted above the link to discussion on Forum. I would recommend having that App by every "not a new hybrid" owner (Dr. Prius App + ). So, you can estimate the expected life of your hybrid battery, it's current condition. You will also be able to read errors and reset them.
Thank you all for posting this info!
I've had my RX 400h for 2.5y and I've been having issues w the car not showing READY, but wait a few minutes and it will start up. Now it won't and I have to jump the 12v w my portable. The hybrid battery hasn't been replaced (126k miles) and the fact that they're $7k freaks me out.
Along w other issues, like not being able to just sit in my car and listen to music w o the hybrid battery bottoming out to Red, has really swayed me away from every buying another Hybrid.
Love the car, but,, Nope!
The condition of 12v battery is important for starting of hybrid system. If your car is READY after each "jump" then your 12v is bad.
PS: Do you have (had) "CHECK HYBRID SYSTEM" warning ON?
PS: Some Toyota dealers have free 12V battery test till end of November.
pakris (11-14-23)
_
_
This is also where the typical warning lights come on around this 'display' area (usually yellow), and then there may be a white-lighted message 'check hybrid' here too. But it could be for many reasons mostly, in my case, a loss of communication from 12v to hybrid and anything in-between that sends the signal/s when operating correctly.
Anyone that is a tech on this board please feel free to correct me as I am an owner and driver learning and sharing my experiences. Thank you in advance! This Forum is great.
Patricia
Strlsn (11-15-23)
pakris (11-15-23)
I've gone down to levels 2 / 3 this summer. WHILE driving a 90 minute continuous mountainous drive.
One reason I seriously debate keeping this RX400H is you can't sit idle or the Hybrid battery will bottom out. Unless I'm wrong.
If I leave my grown kids in the car, I can't leave the keys in the ignition to let them listen to the radio; I can't sit in the car for any amount of time myself listening to the radio while eating or other things; I have to make sure the headlights are off; If we ever got stuck somewhere, and it was cold, we wouldn't be able to leave the car running for heat; If we were in a serious traffic jam on the Hwy and were stuck for a long period of time, again, we wouldn't be able to have the vehicle running.
Please remember that battery vents should never been blocked, otherwise the battery can/will be damaged.
PS: Just set headlights in AUTO mode
I've been told to always use recirculation bc it shuts the vents so rodents won't go in. I've had droppings on the Cabin Filter.
PPS: I wouldn't recommend to use air recirculation (in-cabin air flow) except there is a diesel truck next to your car.
https://www.youtube.com/watch?v=xb0fDfzV41I&t=925s
Interesting, bc sitting in PARK with the vehicle running, OR turned OFF but listening to the radio & / or had the AC or HEAT turned on has lead to to the hybrid battery bottoming out for the 2 years that I've owned it, which leads to not being able to start the car / READY light does not come on when I try to start it again after turning it off. I've had to sit in the car for up to 20m before READY will finally show.
Only recently has it not started at all (still assuming it's the 12v battery needing replacement.)
I've never sat with the car in NEUTRAL.
Passenger area vents are never blocked.
I absolutely only use the headlights in AUTO mode. (unless I'm driving at night (I work nights) or on long drives when I prefer the headlights to actually be on = safer)
No, you can sit in car as long as you want, the only thing is that transmission should be in P gear (never in N). Car will idle when it needs to. Your steering wheel and AC are electric powered, so you can use AC all the time.
