12V battery inquiry (new) from old Thread
#31
Interesting, bc sitting in PARK with the vehicle running, OR turned OFF but listening to the radio & / or had the AC or HEAT turned on has lead to to the hybrid battery bottoming out for the 2 years that I've owned it, which leads to not being able to start the car / READY light does not come on when I try to start it again after turning it off. I've had to sit in the car for up to 20m before READY will finally show.
Only recently has it not started at all (still assuming it's the 12v battery needing replacement.)
I've never sat with the car in NEUTRAL.
Passenger area vents are never blocked.
I absolutely only use the headlights in AUTO mode. (unless I'm driving at night (I work nights) or on long drives when I prefer the headlights to actually be on = safer)
SJM (02-12-24)
#34
Yes, I had been sitting in my car during those photos and was on READY
Don't turn OFF hybrid system ("READY" sign) if you are planning to sit in the car. Just park your car and shift gear to "P". ICE (engine) will be started with hybrid battery if needed (to charge the hybrid battery), but not with 12v battery (there is no starter, as well no alternator). 12v battery is needed to activate hybrid system ("READY" is ON), radio and lights. You should turn OFF the system only to leave and lock the car.
#35
#36
These cars are not designed to "camp" in. The batteries aren't that big. The hybrid system was designed for a bump in MPG in city driving (optimized for 17 mile range IIRC) and performance. If you are looking for a car to park and not have a running ICE, you need a plug-in electric or plug-in electric hybrid.
#37
Unfortunately, I'm far from being able to afford a plug-in vehicle. When I get rid of my Rx400h, I'll be going back to a regular gas-only. May not be good for the environment, and will have to depend on fossil fuel, but 🤷♀️😏
Vincenze (01-03-24)
#38
Just to clarify some things on the RX400h (which can be confusing):
1. There are two separate batteries. There is a normal (small) 12v battery. There is a larger "hybrid", also called a "traction", battery.
2. All driver's displays show the hybrid (or traction) battery level whether on the infotainment center or the center of the dash. There are no 12v battery indicators I know of.
3. Unless there is a catastrophic fault, the hybrid battery never fully charges, nor discharges. When you see it full on the displays, it is only really at 70% of battery capacity. When it shows empty and the ICE starts, it is really around 30% capacity. Toyota did this for longevity.
4. There are no displays for the 12v battery to show you its charge. When you first turn on your key, on the left of the instrument cluster you'll see two batteries displayed in red. The one label "main" is the hybrid battery warning light. The one with no label is your 12v battery charging system warning light (think alternator). This does not indicate the condition of your 12v battery.
5. The 12v battery capacity has always been considered by their owners to be too small in these cars. Toyota/Lexus put a larger capacity 12v battery in the RX450h. Since it is so small, it will drain very fast if anything is left on in the car (interior lights, seat heaters) with the ICE off. You do not want to sit in the car with the ICE off and key ON for any length of time (ie no READY light).
6. As a result of its small capacity, the 12v battery needs to be changed every few years. You'll have no warning lights to tell you this other than it won't start or other "odd" faults.
7. When you turn the key to the ON position (but not START), everything is running off that little 12v battery. Once you turn it to START, the hybrid battery then takes over starting the ICE and running everything. With the ICE running, the small 12v battery is charged.
8. An easy way to tell how your hybrid battery is doing is to just watch your mileage. If it stays the same (and is in the "that's good for this car" range) then the hybrid battery is fine. Anything around town over 24 mpg is doing fine. I get 21-22 mpg on the highway (where the hybrid battery has no benefit).
Hope that long posts helps clarify how the RX400h works...
#39
PS: I would recommend using AUTO mode (+ A/C ON if hot outside) for best in-cabin climate and optimal energy consumption.
#40
Bc it was 5:45am, I had just gotten off work, it was around 50° outside, and I needed to use the rear & front defogger?
It's Fall in the PacNW and temps are btwn 50-30° here now.
What's the weather like where you are?
SJM (02-12-24)
#42
I've gone down to levels 2 / 3 this summer. WHILE driving a 90 minute continuous mountainous drive.
One reason I seriously debate keeping this RX400H is you can't sit idle or the Hybrid battery will bottom out. Unless I'm wrong.
If I leave my grown kids in the car, I can't leave the keys in the ignition to let them listen to the radio; I can't sit in the car for any amount of time myself listening to the radio while eating or other things; I have to make sure the headlights are off; If we ever got stuck somewhere, and it was cold, we wouldn't be able to leave the car running for heat; If we were in a serious traffic jam on the Hwy and were stuck for a long period of time, again, we wouldn't be able to have the vehicle running.
There was a recall/update on the inverter/pm module. Make sure that was done.
#44
PS: Climate control is in AUTO mode always + AC ON if 70+F outside.
Strlsn (11-20-23)
