Can you jump start hybrid battery?
After reading how many have had battery problems with their 350h, I do not think I would offer to help jump start anyone. I own a large portable jump starter but it is heavy and required charging every once in a while.
BillUK you said "A separate point worth mentioning, is that whilst you can jump start a hybrid car from another car/battery pack, you can't jump start another car from a hybrid. The 12v battery/system in a hybrid isn't designed to push out the required power to start an engine, and could cause damage if you try." So you should not try to jump start another car from the front fuse box positive terminal. What about jumping directly from the 12 volt battery in the back of the car? My guess would be that that shouldn't be done either?
jahnjva (01-21-24)
Basically, you are using your vehicle's battery in the same way that you'd use a portable jump starter. There is a concern that it could leave your own battery dead if the jumped vehicle doesn't start right away though.
Your traction battery is under the back seat and impossible to connect to without taking things apart. It's also high high voltage. Your 12v battery is in back under the cargo floor. Usually you would jump it from the front under the hood though. There is a positive connection in the fuse box and a negative connection on the engine.
Here is a video on how to jump a Lexus hybrid.
https://youtu.be/CShZN2P8di0?si=d_cXg3c1OOWVLZCN
desmo907
Hybrid Technology
09-19-24 12:30 PM
