Notice oil leak under car - more towards drive side
Crank seal or the timing cover.
ESh (02-21-24)
Cheap part, but expensive to replace.
where is it located ? if it's visible from the engine bay can you post a picture, thx
edit: never mind looks like a PITA job
No, the PCV valve is seen from the bottom of the car easily. Its a easy job if you have a car lift.
NdYAG (04-04-24)
Thanks is this the part ?
Yep. Thats the PCV valve.
What are you expercing any issues? Or just doing maintenance?
well I wasn't familiar about this thing then from what I read this is a "routine maintenance" item. One resources says new one may be put in at same time of OC.
I'm ordering some parts so I thought I add it in since it's cheap.
Did you need to remove the wheel ? (pass. side)
Yes, that’s the PCV.
wope
10-03-21 01:29 PM
