Trouble Code C-1568 DC-DC Converter aka Power Steering Converter
I would like to make a new thread just for the Power Steering Converter.
This thread will be for diagnosis, troubleshooting, and continued research.
Power Steering Converter aka DC/DC converter: this unit takes the high voltage from the hybrid battery and steps it down to 42V for the Power Steering. A 12V enable signal from the Power Steering Ecu is required for this unit to turn on(see below).
(Posted in fair use for commentary and discussion).
Here's what I have so far on the Power Steering Converter.
>> If any errors, please let me know do I can fix.
There are two wires on the Power Steering Converter that are still unknown.
P46, pin 1(red/rellow): ?
P46, pin3(red/white): ?
>> If anyone knows what these do, please post.
Margate330 (06-02-24)
Checks
I have literally got to a dead end have checked all of the wires resistance and voltage the only thing that I can’t work out is why the 12v on the yellow and black wire (DRDD p41-11) is not being pushed down to the converter to signal it to send the 42v back.
This would not be suspect for a rim curbing.
Refresh: ok, so you say you can inhibit the DC/DC converter to make 42V by applying +12V to the inhibit signal wire(P46, pin2, yellow/black) ?
No sorry this someone has made another thread for me with dc dc converter issue the curbing was not my vehicle.
however I have gained a reading of 42v by adding a 12v battery cable down the p41-11 lead which is the I’m guessing signal lead to the power steering converter which turns into the p42-2 pin.
thanks for your input as like I said at dead end
Just to recap bought a 2006 rx400 h 2 weeks ago.
plugged in power steering fault c1568 present and will not clear.
have followed other thread and also my own research into the wiring.
have checked all resistance and voltage no faults or breaks.
however when car is turned on 42v does not appear unless I manually do the 12v on the p41-11.
have changed ecu and converter but with same exact results.
Ok, P41-11 is the wire from the perspective of the Power Steering Ecu and it looks like you can enable the DC/DC converter to make 42V, GOOD!
Next: from your diagram posted above, only two wires in question left was the signal error wires from the DC/DC converter so I will ignore these for now until we know more about them.
Next: I think we need to know for sure and prove that the Power Steering Ecu is alive and not brain dead. If you have Techstream, can you verify you can connect to this module? It should show up because it's on the Can Bus. If not, can you think of a way to prove the Power Steering Ecu is doing something?
Next: clear all codes with a batter unhook and let us know what codes pop up please.
I think your your right I no I’m close but can’t work out why it would not be sending that 12v.
I don’t have tech stream I have a launch x431 pro and can access a data feed which confirms that the DRDD P41-11 is only feeding the converter 0.4v not 12v. Also when car is on I have checked voltage on the signal leads and it has a voltage reading so can high and can low must be working . However the live feed must be showing that the ECU Is reading and working.
also sorry what is a batt unhook will do that and send codes
Also I have looked at the wiring and this is where the 12v signal come from and I have checked the mpx-b1 fuse and all is ok.
from this Lexus troubleshoot it states if I get a reading of these pins which I do 12.1v to change ECU I have lol. Honestly round in circles
here is a link if anyone wants to do there own diagnoses
http://manualespurdy.cisdigital.com/Lexus/RX400h/rm03g0u/MANUAL.HTM/rm03g0u/ewd/index.html
Yes, a battery unhook & reconnect to flush all codes current and pending and see what pops up please, what I like to call a "hard reset" like on my computer. lol
http://manualespurdy.cisdigital.com/...ewd/index.html
P41-6 & P41-5 are just the input power supply wires for the Power Steering Ecu.
It's just making sure you have +12V to power it. lol
Yes sir, you are correct, it goes to battery/frame ground
It seems like the junk yards are selling bad parts from wrecked cars.
To rule out the DC/DC converter, voltage injection can be done by leaving the DC/DC converter unplugged and injecting 48V directly into the Power Steering Ecu, if I understand correctly.
If your steering starts working, you got another bad Power Steering Converter aka DC/DC converter.
*note- requires a safe way to supply +48V
However, if after voltage injecting +48v with the DC/DC converter unplugged and you are still throwing the code and have no steering, you may have another bad Power Steering Ecu or something connected to it
>> Please see post #30(how to) & #31(warning) here: https://www.clublexus.com/forums/rx-...d-c1241-2.html
