2013 RX450h rear driver side subtle clunking noise
Hi,
I have a 2013 RX450h, excellently maintained. I've started experiencing the rear driving side subtle "clunking" noise when driving. I have checked and made sure all things, e.g., spare tire, etc., are all secured. The struts looks pretty in good condition. No rush or no cracks. I checked to make sure all the bolts around the rear tires are not loose.
I am suspecting the bushings, the rubber pieces on the bar that goes across the rear side under the car. But they are like new. My car is around 89K miles.
Tips/hints are appreciated.
Thank you!
Thank you!
unebonnevi (Yesterday)
Do you have tell tale signs of dampness [oil leak] on the rear shock. If yes then it needs to be replaced ... seems like a common problem.
If not, at this stage, take it to a suspension shop and usually they do a free determination of what is wrong. What ever they or you determine to be the root cause, it needs to be visually determined [play/movement] and it might require long levers.
Salim
Salim
Salim
Salim
