GS 450H official Thread 0-60 in 5.2 SECONDS/25 MPG!!!$54,900
Originally Posted by 1SICKLEX
Like the IS, the motor is transversely mounted to drive the rear wheels, and is mated to a CVT gearbox with a permanent magnet motor sandwiched in between. Seeing as info on the electric half is closely guarded, well have to entertain you with stats on the ICE (gasoline engine)
http://car-reviews.automobile.com/Le...-preview/1500/
The only negative on CVT's have been that they can't handle high torque engines. The GS450h will likely have 330hp, and the LS600h will have an 8sp auto. Getting away from CVT's in these performance hybrids might make conventional transmissions nessasary.
CVT will be used in the GS450h..
as 1Sicklex reported months ago. I haven't seen a drivetrain layout yet but the autoshow site on Lexus.com is starting to reveal information about the GS450h at least. On the RX400h the power blends between the engine and electric motors at the CVT so you will hear revving of the engine but the power and acceleration are incremental so you don't perceive it like you do when manually shifting gears and feeling that sudden pull after each gear. The electric motors add torque in 10 second bursts and then the gas engine sustains it after that. The IS350's V6 is a powerful engine by itself so this will be analogous to going turbo or supercharging it. Its ideal use would be for passing German cars on the Autobahn.....just kidding.
Rock
Rock
Originally Posted by BrickHead
Has horse power been confirmed on the GS450h? Lexus website says over 300. Do you think it will be over 350?
Originally Posted by that_guy
My educated guess is that the GS450h will have 250kw/335.26hp. This is 5kw MORE than BMW's E60 545i. See the link? 545i, GS450h
