GS 450H official Thread 0-60 in 5.2 SECONDS/25 MPG!!!$54,900
#31
New info on drivetrain...
The 3.5 V6 which is longitudinally mounted will have an electric motor as controller, a planetary gear type CVT and another electric motor/generator for drive output all housed together like a large conventional transmission. The power will then travel back conventionally like a GS430. The new wrinkle will be that the CVT has a low/high range that adds to its performance potential and gas savings. This is a good example of the creativity of the Lexus engineers who are blazing a new trail in design of hybrid powertrains. We expect to get it in May....
Rock
Rock
#32
Originally Posted by that_guy
You mean this one? It doesn't go up to 275kw, otherwise they would have marked it. It goes to 250kw. Look at where the zero is. It's not where the indicators begin.
#34
The thing is, if that max was 275, i'd think they'd mark it. I'm pretty sure drivers would like to know that they're using the full power of their car Much like the Bugatti Veyron (1001bhp)
#35
Well, I don't think anyone will know for sure at this point (except Lexus), until you get to drive it and see if the meter will go beyond 250 KW.
Besides, it's the real world performance that really matters, & we won't get those stats. until the car is out & tested.
#36
Originally Posted by XeroK00L
Thanks for finding the pic. I still believe that the maximum reading is indeed 275kw. If you look at the pic the reading is in the increment of 50kW, therefore skipping the number of 275kw. The font of the numbers is simply too large to print them in 25kw increments without making the power meter look terribly crowded. As for the reading below 0, I don't see how that's related to the maximum reading at all. In the end of the day, 275kw simply makes more sense than 250kw since 335hp is barely more powerful than the 306hp gas motor alone, and we all know what Toyota's electric motor is capable of.
#37
Originally Posted by knolex2001
The 0 marking on the kw meter is accurate where it is. The needle will spin up to 275 when it's being floored, when coasting, it's go to 0, when BRAKING it will go BELOW 0.
#38
Guest
Posts: n/a
Rock
Rock
#40
Originally Posted by PhantomZX
I got some newsletter from Lexus saying it's going to be 300hp - a bit disappointing considering the IS350 with almost the same engine makes more than that.
#44
Originally Posted by DetMich1
These have probably been seen before but I think the deep blue is a great color:
