disable seat belt chime?
MultiTasking Mom
you can do everything the 06 GS can do. when they say press start button once, you put it in ACC mode, if it's start button twice, then put it in ON mode on your ignition key
1) Get into the car w/ ignition off and close the doors
2) Turn on car and Set the LCD on the combination meter to the ODO display using the ODO/TRIP button (put on odometer, not trip meter), then turn off car again
3) Turn to ON mode (2nd position on ignition switch)
4) Hold the ODO/TRIP button. Wait ten seconds, and while still holding the button, buckle the driver’s seat belt.
5) The LCD displays "Seat Belt Buzzer On/Off". Release the button. Pressing the ODO button toggles the On/Off
Lexuslover,
Thanks for the directions, it worked! No more chime After you start driving, the initial chime when you turn the car on is still there but its not nearly as annoying as the 2nd one.
What other tricks do you know?
MultiTasking Mom
Originally Posted by gs4to4
Lexuslover,
Hi,Lexuslover.Do you know if these tricks apply to UK spec RX400h's?
Could let me know the one for the automatic door locking/unlocking as this would be particularly useful.
Cheers!
Cheers!
MultiTasking Mom
Cheers!
Cheers!
it's a nice thing to have. i sometimes back out of the garage and then somebody hops in to join me, and the problem is the factory setting would lock the doors as soon as i shifted out of P. now i can back out and have someone open the door without me unlocking. (and then it locks once i reach 12mph, which is in about 5 sec when i leave)
cbarrett (04-23-20)
