Tire Tread Wear on RX400h
Hi. I need some help. I have an '06 400h that was factory equipped with Goodyear Eagle RS-A tires. I noticed an uneven tire wear pattern after about 10K miles with the wear being heavier in the center of the tire. I have been very conscientious about proper tire pressure at 32psi as suggested. Now that I have close to 24K miles the wear pattern is more pronounced and the Service Manager at Lexus in Silver Spring shrugged his shoulders and offered to partially cover the cost of some new tires. I am very curious as I also noticed that most Lexus vehicles are equipped with Michelins and it appears that the Rx400h is peculiar being equipped with the Goodyears.
1. Can anyone else confirm this problem on their Rx400h ?
2. Has anyone heard a reasonable explaination ?
3. Has anyone heard of a resolution?
I know I've got alot of miles on my RX, so I may be one of the first to notice this issue, but please keep an eye out.
Thanks for the response. That's exactly when I started to experience the problem. Did you try going back to the dealer for resolution. Or did you just bite the bullet. My dealer was going to pay 40% of the cost of replacement tires, but I think that Lexus should be fully responsible. It is an expensive vehicle and to put on an inferior tire is ludicrous.
We have a 400h also; Goodyear tires are shot at 17000 miles. Keep in mind this is all highway driving; the wear pattern is actually on the inside. We took this in every 3000 & 5000 miles for oil & rotation. I had three
tire stores confirm they DID NOT rotate these tires. I will find a 40000 mile tire. On a BIGGER note; I remember being told the brakes would last LONGER because the electric motors help stop the car. From what I'm looking at it's the opposite. are brakes are gone at 18000 miles CRAZY. all highway. Car makers are car makers
My other car is an Infiniti G35 coupe. The original equipment tires were RSA's and I had the same wear problems with them. At around 15K miles, there was much heavier wear on the center rib of the tires than on either edge. Looked like over inflation except that the tires were always at 30 psi. I suspect that this is a design issue with the RSA tires.
The RSA is used in a lot of applications as an OEM tire. The reputation is that they ride well but wear fast. The alternate tire for the 400h is the MXV4 which does not ride or handle as well as the RSA, but wears much better.
Steve
Steve
I have 10k miles on the Goodyear RS-A's that came with my RX400h. I don't see abnormal wear in the center, if anything I see a little more wear on the outer edge. But only on the front tires. I added a little more than the recommended pressure to the front tires a couple weeks ago, will see what effect that has.
Look at the tread wear rating on the Goodyears, They are I believe only 270 where as the Michlines are 400. Thats why Goodyears Dont last long..When I bought My 400H last month, I had them put Michelines on...I noticed some 400's had Michelines and others Goodyears..
Try to look for a reputable shop (not those fancy-chained shops) and let them inspect your alignment (usually under $30). If you need more tips about shopping for tires.... msg me and I can refer you to my budy who works in the shop, who loves to provide info on tires for different driving preferences w/wo selling any.
2. Noticeable center wearing is not normal. It can a cause of: often long term driving, lacking of tire maintenance (rotation, high tire pressure), over loading, or possible a defectivly manufactured. Again, tires with VR spec is good for high speed, short term driving, and also not for heavy loading (just think VR tires are for track use... good handling and high performance but not for long lasting)
3. Resolution? Get new tires, check your alignment and stop going to dealer. Because quality tires with a cheaper price tag and also an alignment technician with 20+ years in alignment only do not exist in dealers)
I will not pick up VR tires again if I am drove 24k mi in one year.
My 400h has 12,000 miles and the Goodyears are essentially over the hill. I could coax another 4,000 to 5,000 miles out of them but I've seen too many accidents on rainy days. The tire face has good tread but the inside track is wearing fast. I've got the Bridgestone dealer bringing in four Alenzas which have a significantly higher tread rating than the Goodyears. The local Tire Kingdom (Merchants) store could not get them for me. All they offered were the Michelins with VR speed (VR = soft rubber = short tread life). I've had two sets Michelin Pilots on our RL and did not like the tread life. The original VR Pilots were hydroplane city at 18,000 and the slower speed (can't remember the speed rating but it was the slowest speed rating for the Pilot series) went 25,000 miles and became distrustful. Have Potenzas on the RL and they are looking good, running good and have 13,000 miles without showing wear. Anyone out there with Alenzas on their 400h? Did you lose much traction? Any comments?
I'll let you know how it goes when the tires are put on next week. I've put 65,000 miles on Michelin LTXs on a Yukon. My son has 65,000 miles on LTXs on his Explorer and they look great with no hydroplaning problems. The stuff I've read on the Bridgestone low profile tires having much longer tread life appeals to my mid-fifties sensibility (i.e. not doing much racing these days, but I do want to look good while getting respectable tire life). You'd think Michelin would get the message and come out with some longer life low profile tires.
wstr
wstr
Super Moderator
Go with the Michelins when you get the chance. Other advice it to inflate those tires with nitrogen, which you can get at Costco. My tires have lasted a lot longer than they should have.
Lexmex, thanks for the advice, but I've already committed to putting Bridgestone Alenzas on my car. I'll be the group's guinea pig!
I've been a Michelin guy for most purchases the past ten years. I've been real happy with the Potenzas and the on-line tire research has spoken highly of the Bridgestones followed by the Yokohamas so I'll report back with my experiences. As to the Goodyears, I rotated the tires every 5000 miles but I guess they just weren't happy with my driving. I've had similar experiences with Goodyear Eagles. The high performance Goodyears do have good dry road grip, though. But I'll give up some cornering G's for better tread life. The Tire Kingdom manager said that the 55 profile tires were pretty much all VR ratings. The price we pay for bling, bling-looking wheels my friends.
Super Moderator
