Pros & Cons of the Lexus 400h?
How much are you really saving the environment with a hybrid? Think about disposing off the huge battery at some point in the car's life. Can it be disposed off properly or will it damage the environment?
Another point to note is how are your driving conditions. Is it all bumper to bumper city driving (where the hybrid shines), or is it more of a mixed type driving or highway driving. If it is more mixed and or highway, you may not really gain any benefits of fuel economy from a hybrid. Bongos is averaging 27mpg and I don't think even a hybrid will do much better on the highway. Performance wise, the RX350 and 400h are about the same.
-Hybrids will depreciate faster than the gasoline counterpart.
-Hybrid technology is still advancing rapidly and a 4-5 year old hybrid may become obsolete quickly.
A 2000 Corolla with a 125hp 1.8 litre VVT-i engine is more powerful, cleaner and more fuel efficient than the 1995 Corolla LE with the 105hp 1.8 litre engine.
Our 02 Camry's 4-spd automatic is ancient compared to the new 5 and 6 speeds
and so on and so forth
-The big battery will need to be changed at some point in the car's life. This is very expensive. I don't know if Lexus covers this.
-Hybrids are very complex and it is more probable for something to fail....although I do know that 400h is a very solid vehicle.
-Towing is not allowed on the 400h whereas it is allowed in the 350....in case you are interested in that.
-The 400h is not full time 4WD whereas the 350 is full time 4WD.
Hope that helps.
'06 400h manual:
The total trailer weight (trailer weight plus its cargo
load) must not exceed the following. Exceeding this
weight is dangerous.
Without towing package 907 kg (2000 lb.)
With towing package 1588 kg (3500 lb.)
Toyota Highlander hybrid and RX400h are based on the Nickel Metal Hydrid Technology which has a low cycling (charge/discharge about 500-700 cycles) rate and a self discharge rate (loses 20% of capacity per month). Since the cycling rate increase with less use, this is an advantage for the the hybrids (exp: say you only use 50% of the battery consistently before it's charged again, now your 500 cycle is increase to 1000 cycles, this is linear so if you use 10% you get 5000 cycles, Toyota has it's computer monitoring this to make the most of the battery). In regards to the self discharge, Toyota created a seperator cycling battery modules to lower self discharge to about 10%. Right now they are looking into Lithium technology, before Lithium is a No No due to it's violent chemical unstability....this is mostly Lithium cobalt based, now lithium technology has come out with a safer battery and you will be seeing this in the new few years.... so yes, the NiMH can be obsolete technology in hybrid as early as 2008.... that Toyota plant will probably start operations in the next few years
Now as far as AWD, I am pretty sure that the RX350 is full time 4wd and the RX400h is FWD until slip is detected. The RX350 has the advantage here with better snow capability and zero torque steer. The RX400h does exhibit torque steer even with AWD.
Kan-O-Z
Our 400h was bought for $1500 under MSRP. That was about a $4500 profit over invoice. At that premium, it was just at our threshold for "worth it," based on the bogus EPA estimates on the sticker (another story altogether). That said, once we figured out how to drive it, the mileage got a lot better.
Now, hind sight being what it is, is the 400h better than the 330/350? In my opinion, probably not. It depends on your goal. From a purely financial perspective, absolutely not! Not at the prices the dealerships are charging. And until uninformed people (like I was) stop paying those amounts, there is little incentive for the dealerships to change their pricing. We love our 400h, plain and simple; but we paid too much for it.
DLeebold (01-02-21)
I stand corrected ...
FROM THE LEXUS RX brochure:
RX 350
"Full time all-wheel Drive (AWD) with viscous limited-slip center differential and standard Vehicle Stability Control (VSC)"
RX 400h
"Part-time all-whell drive (AWD) with standard Vehicle Dynamics Integrated Management (VDMI)"
Can anyone tell me EXACTLY what this means? If this is a different system from the RX 330 (to the now RX 350) it's impressive that they well to a full-time AWD and gained (minor gain) fuel economy (city from 18, up to 19 ... highway is the same).
How much of a difference does this make when comparing the two AWD systems? Not THAT big of a deal, but still.
It's also a little interesting how they reduced the size of the gas tank (17.2 vs 19.2 gallons in the RX 350) for the 400h ... probably for space ... weight-wise it doesn't hurt either.
RX 350
RX 400h
RX 350
RX 400h
RX 350
RX 400h
https://www.clublexus.com/forums/sho...34&postcount=9
Thanks for posting it!
Thanks for the info. Yeah, I heard that NiMH is getting expensive and is also another reason to switch (I'm guessing it's the nickel part lol). Since CalCars and other companies have seem to successfully mate Li-Ion batteries to their plug-in hybrid versions, hopefully that means if and when I'll have to replace mine, I can upgrade. Not sure if the HV ECU needs a flash too to update its perimeters and other programming instructions.
RX 350
RX 400h
RX 350
RX 400h
Kan-O-Z
FWIW, NiMH batteries can withstand cold weather conditions much better than LiOn type cells. A major point for those in the Cooler / Cold Climates.
Cheers.
MadloR
Cheers.
MadloR
Cons RX400h:
-Cannot be towed
-cannot be left idle more than one week (dead Battery will occur if left idle longer)
-Only has part-time all-wheel drive vs. full time all-wheel drive on the RX350
Is this correct so far? I also read that the 07 RX400h comes with fabric seats standard and navigation is now an option. I think the 06 RX400h had leather and navigation standard. Can anyone confirm this? Thanks.
-Cannot be towed
Cons RX400h:
-Cannot be towed
-Cannot be towed
As for the full time vs part time (on demand) AWD, there are some reasons many of us prefer the on-demand system. The most important is that full time AWD consumes more fuel in normal driving for little or no tangible benefit. The 400h AWD fills in instantly when traction is needed and when more power is needed since it is a source of additional electric power. That is why the AWD 400h is faster than the FWD. It is also, according to Lexus specs, a half second faster from 0-60 than the AWD RX350.
The marketing for the 400h has changed from the original plan. Originally it was only available fully loaded with leather, nav, 18" wheels and its base price was set accordingly. Sometime late in the 2006 model year Lexus changed the base to cloth seats, 17" wheels, and no nav and reduced the base price accordingly. I have never seen a 400h equipped any other way than loaded just as I have never seen a RX350 with cloth seats and 17" wheels. The base model may be available somewhere, but not in Arizona.
Steve
