LS600hL road trip
#91
A Little better gas milage on return trip...
During the stretch from Wendover to Reno, I got 23.5 MPG (added 1 MPG) - probably because of "break-in" (now up to 2500 miles total on the car).
I still averaged 88 MPH, 2 adults/2 teenagers, and a full trunk of suitcases - so I don't think this is too bad - like I said, I didn't get the car for gas mileage - and I wasn't driving to save gas - just get across the desert as fast as I could safely.
The other plus is I still had a hundred + miles of "gas" in the tank - all the way across Nevada with gas to spare - we didn't stop at all.
- Darryl
- Darryl
#94
I do feel like I'm babying the car a lot to get that mileage, FWIW. One thing I am curious about. When approaching a stop in a hybrid, do you save more gas waiting to brake relatively hard, or coasting as much as possible with the car slowing down and braking softer. Does the regenerative braking create more electricity with an abrubt short stop vs a slow coast and gentle stop?
So gliding (that is, no arrows shown on the Energy Monitor) then braking to a stop gets you more than coasting (green arrow on Energy Monitor) all the way to the light.
Ideally, you would glide to the light (if it's a flat ground, you'll be losing speed anyway but not as much as if you were to coast) to maintain as much momentum as possible, then when the light goes green, you can continue.
Of course, that's assuming you wanna maximise mileage .
Same as going down a hill. Pressing on the brake pedal will send more electricity back to the battery than coasting down the hill. How far you depress the brake pedal will determine how much you'll generate back to the battery. On the Prius, I believe 100amps is the max. I don't know what the figure is for the LSh.
#96
Regenerative braking takes up the slack in case you need to brake thereby recovering some energy to be used later rather than throwing the momentum away by converting it to heat when the pads touch the rotor. I drive 90% in the city and my brakes are pretty much brand new. I expect the LS ones to last the life of the car too if driven gently.
