How do I watch dvd on nav screen?
Out of Warranty
Not sure how it works on the '08, but my '04 works like this: Transmission in "Park", set the emergency brake (principle here is to assure that you are not underway while viewing video on front screen - illegal in many states). Start video on RSES and press the "DISC" button on the radio stack twice to switch to "Aux" input. That should bring up the video on the screen and audio through your speakers.
When all other options fail, check your manual!
Out of Warranty
I can't imagine the M/L system having anything to do with it. The upscale audio option consists only of a change of speakers, an uprated head unit, and the addition of that center channel speaker in the top of the dash - the connections, I think, are identical. My RX 330 has M/L, but only because early editions of the 330 were available only with a couple of "packages". If you wanted the RSES, you took the M/L, along with a boatload of other options.
O...can I watch VCD instead then?
Also I have an iphone, is there any way I can watch the movies on the nav screen with it?
What would be the mininal and easiest setup...?
thanks in advance,
soda
thanks in advance,
soda
