Engine Warm up before Driving Out??
I observed that the milage comes down drastically after I start the engine. Is it good idea to warm up the engine before driving off??
Super Moderator
I usually do about 30 seconds before I pull away. About 3 minutes in park warms up tranny enough and about 13 minutes will fully warm up the vehicle in park.
No matter what your engine will have to warm up and obviously it will take longer and suck down more fuel when its colder out.
I've found that in ours we see between 20-23 MPG in the first 5 minutes of driving, but after that it jumps to between 26-30 depending on the kind of driving that you do.
http://www.greenhybrid.com/compare/m.../car/5831.html and you can see all my gas milage records.
You will get the best overall mileage if you don't warm up the car. It is true that initial mileage will be low when you start cold, but during the warm-up period the mileage is zero since you are burning fuel and not moving. Best results are to drive with a light throttle until the engine is warm. The electric part of the hybrid system and the CVT will help some, but avoid rapid acceleration and high speeds with a cold engine. Letting the engine idle for long periods slows the warm-up and is not ideal for circulating cold oil.
Steve
Steve
yea...unless it's real cold there's no need to warm up the car more than 30 sec
Other than it's at 0 MPG, idling engine also releases twice as many exhaust fumes
Not only your engine needs to warm up but other parts need to be warmed up as well such as tires
Just remember not to floor it when you just start driving the car
soda
soda
qewani1
13
10-04-08 04:38 PM
