Life of Hybrid System
Any thoughts or advice: I have a 2006 Rx400h with 80,000 miles. Knowing that the wrranty on the hybrid system expires at 100,000 miles, I am wondering what kind of life I might expect from this system? I have heard 3rd hand that the system in Prius cars have typically gone 200,000 miles or more. I really like this Rx400h and would want to continue with it...but, with a hybrid system failure out of warranty, then big $$$$.
Thanks.
WAH in Greenwich, CT
Thanks.
Thanks.
Thanks.
http://pressroom.toyota.com/Releases...T2008092372406
$2,588 for the battery, that sure is cheaper than a transmission!
Thanks.
Thanks.
As far as the cost of a new battery vs cost of a transmission, it is a given that at some point the battery will require replacement, but only a possibility for the transmission. Of course the hybrid has the power split device gear set which hopefully never, but could, require replacement at a very high cost.
When you say "hybrid system" I assume you mean everything on the vehicle that isn't on the standard engine driven vehicle. This would include the battery, traction motors, inverters, converters, generators, control systems, and motors needed to drive components that are belt driven on a conventional car. Just the added number of these components increases the likelihood of failure. The complexity of the control systems would add to the diagnostic costs and require paying the higher costs charged by the high end dealers instead of the local repair shops. It would not be possible to give a definitive answer to the question " what kind of life" to expect, but I would expect to be required to spend more money in the second 100,000 miles on a hybrid than on a conventional. How much is anyone's guess.
Another good thing that due to design, other engine components require less maintainance as less strain is put to them...
"I would check Prius boards to find out more info"
Before I spent major money on my Rx400h, I spent hours on the multiple Prius forums trying to find owners that had to replace their batteries. Good luck finding even a handful of battery failure reports and the Prius has been out for 10 years or more. I concluded that the risk of battery failure wasn't worth worrying about.
According to a report that was recently posted in the general chat section, Toyota has only had to replace about 300 batteries worldwide. Thats pretty good for a company that has 1 million hybrids on the road.
Wow, that's pretty good. I've had some ****ty experiences with American cars (AKA FORD and their transmissions dying a month after the warranty expires). . .also had some issues with German engineered cars (Mercedes especially). . .that's why I like Japanese cars. I know I should support our economy and buy vehicles made in the USA. . .but if they're crappier and/or you end up spending more for repairs and whatnot, why bother?
Gojirra99
Hybrid Technology
02-16-07 08:52 AM
