Poor gas mileage
#31
I just bought a 2008 Rx 400h with 28k miles as a CPO from a Lexus dealership. It had been sitting on the lot for months and the battery was replaced just prior to my purchases.
I've been getting 24MPG with mixed driving 50/50 city/highway.
I figured it is time to do the reset. I followed the instructions.
A few notes:
I was unable to get the battery to charge up completely. When I was hitting the gas, the KW were pretty much not doing anything - the engine was running, but no change in the power meter. The energy flow meter seemed confused between sending power to wheels, battery, and to motors.
I cannot get the battery to fully charge no matter what. It still has one bar left to go.
Any ideas?
Will post later if milage gets better.
A few notes:
Any ideas?
Outside temperatures
Winter fuel - do they put additives in your fuel in the winter? They do in PA. I lose about 2 MPG in my Subaru because of it.
Tire pressure - again, cold temps = cold tires = lower pressure = lower mileage
Fuel grade - what kind are you using. On highway trips I found that it is more efficient to run 89 than 87. Haven't tested 93 yet.
#32
Hey guys - I have a new to me 2007 400h awd. When we first got the car, it said it was registering around 26.5 mpg. We reset it and now, after we've had it a couple months, it's registering anywhere between 21.5-22. This does seem pretty low. I don't know if it's because it's been so hot and the ac runs all the time or what.
Something I've noticed is when you're looking at the display in the spedo with whether it's running on engine, battery, or both, it seems to almost always be running on engine. Even when you're taking of from a dead stop and lightly press the gas, it goes straight to engine and no battery. Doesn't seem to matter how much battery power is left, it just does that. Any thoughts? Should I be concerned? I need to take it in for an oil change next month and I guess I'll have them look at it then unless any of you guys had an idea. Thanks!
#33
How is your 12 volt battery? If it's weak, you might be losing your ISC reset.
Other factors - tire pressure, gas (brand and octane), dragging brakes (regular and/or the parking brake, faulty computer (as in it's showing 17mpg, but that's not what you're actually getting - consider measuring your fuel economy manually), 02 sensor(s) - if you're not getting a check engine light, they just might be 'lazy'..
#34
The 12V checked out ok. I use only exxon or shell gas and I've played around with the octane. Worse with 89 and higher. Tire pressure fine, I calculate my own MPG to be a little lower than what the computer says. It doesn't come up with any bad "codes" when they check it. No light on my O2 sensors i had this problem on a Honda so i know what to look for. What gives?
#35
Black magic?
We just bought a 2008 RX400H w/ 18,500 miles. It is 3 years old (Jan 2009 in-service date).
We had it shipped to us and on arrival the car would not start w/o a jump. It did this two more times before it settled down to starting normally w/ the same battery. I gave it a couple of battery charges along the way. Not sure what the heck was going on.
Anyway, on our first full day of in-town shopping with the car AFTER THE BATTERY NONSENSE HAD ENDED and we got just under 30 mpg (20 miles). Then we drove to a nearby town (more shopping) and averaged 26 mpg in 50/50 mixed city/highway. This is w/o doing any of this ISC resetting stuff.
When you start the car (Ready state), the engine normally turns on after a few seconds, even w/o the car moving.
I am really suspicious of this ISC resetting stuff that seome people are pushing, at least as far as mileage improvement goes. Our battery was clearly VERY weak, we did no resetting and we got near 30 mpg. What will a ISC reset do...get us to 40 mpg?
- nopcbs
- nopcbs
#36
I notice that as soon as I put on the heat with any hybrid vehicle the engine kicks on even when your parked. This can cause significant reduction in fuel economy because the engine is always on in the winter. However the AC can run on electric and does not force the engine to turn on until the battery is drained. I personally would not buy a hybrid if I lived in a cold climate.
#37
As I've posted elsewere, there is a separate electric pump to keep the coolant circulating through the heater core, even when the engine is off and the mechanical water pump is not providing coolant circulation. This electric pump is specifically there to allow heat while the ICE is not running.
#38
Be careful what you compare
Winter makes a difference how hybrids behave. The engine will run more to heat its coolant and to also heat the car interior plus the NiMH battery needs to be heated to operational T.
Your mileage will suffer and the engine will run more in winter...unless you live in a climate where there is no real winter.
I just had the invertor replaced and the dealer replaced the battery anyway. I noted that the car previously wouldn't start the gas engine while I was in the garage. Only after pulling into the road (normal). Recently, the gas motor would fire up while in the garage. I tried the reset and so far, I don't see much change.
Does EVERYTHING have to be off in order not to have the car start the motor up right after turning the key to "ready" mode? ie.. lights, defrost, radio etc..??
#39
So if I understand this correctly, one should do the ISC reset every time the 12V gets replaced? I bought my wife a used 2007 Rx400h with 83K miles on it from an out of state Jeep dealership. According to carfax.com, the dealership replaced the 12V battery, wiper blades, oil change, and tires (I even got them to change the windshield since there was a crack). I drove the car Az to Ca average 70mph and got an average 26mpg. Our stop and go city mileage has been about 22mpg and 75mph driving to Las Vegas nets 24mpg. The best mileage we see is when we're driving in slow-and-go congested traffic (5-30mph with no few stops) under this situation, we see 31mpg. I will try the ISC reset and hope for an improvement. This has been a little disappointing for me since I get 46mpg in my 01 Vw Golf TDI...I even get 28mpg when racing at the Buttonwillow track (4-cyl TDI has tiny fuel injectors).
#40
maximizese, you are already getting pretty decent MPG. The road condition also dictates the mpg, whether you are going up slope or down, or smooth 30-35mph on flat road where you can go full hybrid as long as the traction batteries allows you to before needing to recharge. The most i've got was on freeway doing about 55-60mph I get close to 30 mpg and a couple of times I have full traction battery charge up, after fueling up and reseting the trip computer, I was on full hybrid for a few blocks, I get up to 84 mpg then it drops down to regular high 30s then to high 20s. The RX is not a prius it doesn't get high MPG period and you can't really compare the RX to your Golf, so much in weight differences and gasoline electric VS diesel engine.
just my 2 cents
just my 2 cents
#41
just my 2 cents
just my 2 cents
#42
drive the 2007 Toyota Harrier - Rx350 , which is 3.3L V6 , which is the exact same model as the Lexus Rx400h, except it has smart key & push button start feature. Tried the ISC reset like this
1) making sure the right temperatures , etc etc,
2) Press the breaks, push start, then press the accelerator& brake together for approx 30sec,
3) Shut off the engine and place it in park
4) Wait 5 seconds.
5) Turn the ignition but pressing the brakes and push start
6) make sure the A/C and heater system controls are set to off
6) Lightly step on the accelerator pedal until the engine starts -then immediately take your foot off the accelerator and let the engine run until it stops by itself.
the engine ran for less then 30secs and stopped. so i guess it worked, lets see how it the mileage is.
4) Wait 5 seconds.
#43
resetting the ISC
Have you tried resetting the ISC (the ISC learning procedure). ISC is the idle speed control. If the battery has ever been replaced, or run down (or even below a certain voltage, the ISC needs to be reset, otherwise the engine idles too much. There is a TSB that explains how the dealer should do it, but it can be done by an ordinary mortal without the dealer only Lexus diagnostic computer.
See here for instructions - http://us.lexusownersclub.com/forums...howtopic=58930
I did this after buying my vehicle used (and then running the battery down fooling around with the NAV system without the vehicle in READY mode).
My around combined highway/city mileage went from 10.2 litres/100km to it's current 8.5 l/100km.
Garybuyit
