Has anyone ran 275/35-18 tires in the rear with stock wheels?
I am considering dumping my crappy stock Bridgestones for some Michelin Pilot Sport 2s and saw that I could run wider tires in the rear on the stock rims. I'm not really interested in new rims as I don't want to go much lower profile for ride quality's sake but I am interested in getting more torque on the ground.
Of course, the drawbacks are not being able to rotate, but has any one run a setup like this on their 450h and did you have better grip from a standstill? Currently if I slam the throttle from a stop the traction control generally steps in and I'd prefer not to turn it off and burn out. .
Well, I'm basing it on TireRack stating that as an alternate fitment. I'm sure that it will have a little hang over the rim, but since I've got roll-control I have no choice but to go with the stiff side-walled runflats.
Thanks
man0fsteel:
Actually, the problem is much more "overt" than that. . roll-control is called Active Stabilizer Suspension System in Lexus-speak and it basically has electric motors attached to the stabilizer bars that torque them in such a way as to counteract body roll when you are cornering. The net effect is it makes the car's handling MUCH better and eliminates the need to counteract body sway when turning. It also is a better compromise than having extraordinarily strong anti-sway bars as it allows for a smoother, more comfortable ride when high performance handling is not required.
If you have this system, however, the electronics package and supplemental battery take up the space in your trunk where your spare tire would normally go which leaves you with no choice but to use runflats.
Here is the Wiki: http://en.wikipedia.org/wiki/Active_...pension_System
and here is the Lexus video on the system:
http://www.lexus.com/lexus-share/dem...s/asss_nav.htm
UCrazyKid
IS F (2008-2014)
13
08-29-09 07:42 PM
